crazy gfx question
Old Jan 3, 2012 | 11:17 PM
bigreed91's Avatar
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
crazy gfx question
Hey guys so i got kinda a stupid question but i feel its worth asking. So i got a 90 camaro rs and the stock spoiler is off right now cause the car was painted and i just havent got around to puttin it back on. But my car has had a shaking problem after about 68mph and ive replaced a few things and think the rear needs alligned, but my question is how functional is the stock spoiler and would having it on and any downforce it creates help supress somewhat the shaking? Just curious thanks.
Old Jan 4, 2012 | 02:23 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Re: crazy gfx question
The stock Camaro spoiler won't provide much downforce at all. It will not suppress the shaking.
Take a look under the car, as soon as possible. It should not be shaking.
Old Jan 5, 2012 | 12:03 PM
bigreed91's Avatar
Car: 1990 camaro rs
I dont mean hide the shaking, im gettin the rear end aligned here soon and ive had it on a lift a couple times and aint seen no problems, i was just curios if chevy put it on there to be somewhat functional and if not having it on could cause some shaking at higher speeds
Old Jan 5, 2012 | 12:59 PM
85irocinjected's Avatar
Car: 1991 RS
Nope.
Make sure all your LCA, PHB and TA bolts are tight. As well as your wheels being balanced and lug nuts tight.
Old Jan 5, 2012 | 01:32 PM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
If all of that doesn't fix your shaking, have your drive shaft balanced and/or replace the TCC solenoid if you think its coming from the tranny (unplug the electronics on the drivers side and see if that makes it stop)
Old Jan 5, 2012 | 02:17 PM
bigreed91's Avatar
Car: 1990 camaro rs
Ive already put a balanced aluminum shaft in and i replaced the tie rods and had the front aligned which fixed the shaking coming from the front now ive just been tryin to figure this rear issue out
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
LittleFranks
Sep 17, 2015 12:22 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
