weather stripping questions
Old Jan 24, 2012 | 12:55 PM
eboula24's Avatar
Car: 1984 camaro z28
Transmission: 5 sp
i basically dont know what each part of weather stripping is called..i need the little piece that is attached to the triangle part on the front of the window, the part on the door itself at base of window and the weather stripping section that the window rests against..whats the best/cheapest place/site youve found them at, and are there kits for all of them or is it better for me to find them individually? specific names for each part would be appreciated to help me look them up too.
the 1st pic has the triangle seal and the stripping at base of window both..as you can see theyre pretty shot
Attached Thumbnails weather stripping questions-weatherstripping2.jpg   weather stripping questions-weatherstripping1.jpg
Old Jan 24, 2012 | 01:18 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: weather stripping questions
I like the GM stuff the best. on the triangle grab some from the junkyard from a 92, they are 1 piece and look nice..
Old Jan 24, 2012 | 01:29 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
we do offer both of those seals if you're looking to go new
Triangle Seals
Roof Rail Seals
Old Jan 24, 2012 | 01:39 PM
eboula24's Avatar
Transmission: 5 sp
ok, cool. do you know what the other part is called at the base of the window? i take it you guys dont have that?
Old Jan 24, 2012 | 01:40 PM
eboula24's Avatar
Transmission: 5 sp
you know how easy those are to get off without damaging them?
Old Jan 24, 2012 | 01:55 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
they bolt on... the door card.. they are held on by 2 10mm bolts.. i just took mine off because im repainting the car.
Old Jan 24, 2012 | 02:08 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
the ones at the base of the window are usually referred to as sweeps or felts, which we also carry
window sweeps
Old Jan 24, 2012 | 02:18 PM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
never heard about those being 1 pc on the 92 models, are you sure they changed it for just the last year? also, the ones from 1A look to be 1pc too.. just got me wondering
Old Jan 24, 2012 | 02:34 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Check eBay or amauto parts
Old Jan 24, 2012 | 05:35 PM
TTOP350's Avatar
I have seen them on some 91s also.. I put them in my 89 formy 15yrs ago or so when I repainted it.
Old Mar 7, 2012 | 07:45 PM
DJK90IrocZ's Avatar
Car: 90 Camaro IROCZ
Engine: 5.7L TPI
Transmission: Auto 4 speed
Hey Dan or Tony....
How do I remove and install the roof rail weather stripping on my hardtop? Do I need to take off the black plastic trim pieces off or do I just pull it out?
I appreciate any help that you can provide.
Thanks in advance....Doug
Old Mar 8, 2012 | 12:33 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
its been a long time since i had a hardtop, but i'm pretty sure the weatherstripping is just glued in place. a heat gun/hairdryer may help get the glue a bit more pliable, but chances are its all still going to fight you to come off
Old Mar 8, 2012 | 09:27 PM
DJK90IrocZ's Avatar
Engine: 5.7L TPI
So I am assumming that I need to take off the black trim that is on the A pillar first?
Do I just glue it back on or is there screws to hold it in place?
Thanks again...
Old Mar 9, 2012 | 08:53 PM
ckelton's Avatar
Transmission: T-5 Manual
Haha same seat covers that are on my rear seats. Peeled the covers off to see the shape they were in but only found foam and wire...
1992 Trans Am
May 10, 2023 07:19 PM
I'llrocya
Exterior Parts for Sale
Nov 11, 2015 05:45 PM
LittleFranks
Sep 17, 2015 12:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
redmaroz
Aug 16, 2015 11:40 PM
