body panel match up
Old Jan 28, 2012 | 11:28 AM
andrew91fbird50's Avatar
Car: 89 Formula
Axle/Gears: 10 bolt 2.73
body panel match up
when doing a pre 91 bumper swap, does the 91 hood fit the pre 91 head lights? also does anyone know if the ground effects on the rear pumper are removable? i havent had the chance to look my car over yet since i havent gotten it home yet
Old Jan 28, 2012 | 03:41 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: body panel match up
The hood is the same from 82-92.
The headlight brackets, that hold the sealed beams, the headlight doors, and the sealed beam closeout panels are different 82-90 and 91-92.
The front park lights are different between 82-90 and 91-92.
The ground effect on the rear bumper is molded into it and can't be removed.
If you're going to remove the ground effects, there will be a number of holes that will need to be filled.
Old Jan 30, 2012 | 05:27 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
In addition if you are swapping on the 85-90 style ground effects then there will be several new holes to drill in the body as they are different locations from the 91-92 style effects locations. The unused holes should all be patched.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
kkirch15
Interior Parts Wanted
Aug 28, 2015 10:03 AM
tcflint
Exterior Parts for Sale
Aug 26, 2015 05:45 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
Exxon Limited
Aug 9, 2015 08:13 PM
