New Hood louver question!!!!!!!!
Old Feb 4, 2012 | 04:17 PM
88Camaro1993's Avatar
Car: 1988 Camaro IROC-Z28
Engine: 305 V8
Transmission: Automatic
Axle/Gears: Posi
Ok so i have new hood louvers for my car, in the process of spraying them black again and now i have a question...
Is there supposed to be some kind of rubber in between the louver and the hood? because there are these rubber gasket looking pecies on my hood atm....
Heres the picture of the hood right now...
Attached Thumbnails New Hood louver question!!!!!!!!-2012-02-01_15-12
Old Feb 5, 2012 | 02:00 PM
Engine: 305 V8
Axle/Gears: Posi
Re: New Hood louver question!!!!!!!!
bump please help!
Old Feb 5, 2012 | 02:02 PM
Engine: 305 V8
Axle/Gears: Posi
and does anyone know if i need special clips or anything to mount them????
Old Feb 5, 2012 | 06:10 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
The service manual (91) shows no rubber gaskets or sealer. Torque for nuts (51) to 5 N.m (44lb. in.). I also notice it does not show any rubber gaskets or sealer for the ground effect bolts that go into the interior quarter panel. I had mine (ground effects) off Friday and there was clearly some sort of RTV sealer on the nuts. If it were me I would just run a small bead of RTV around the holes prior to install to insure water tightness.
Old Feb 5, 2012 | 07:18 PM
ares88iroc's Avatar
Car: 1988 IROC-Z Camaro
Engine: 355 TPI
Axle/Gears: BW 9 Bolt 2.77 Posi
Wow who ripped your louvers off! :O haha but yes there are little cushions in about 8 different spots or so under the each louver. The louvers bolt in at the underside of the hood (you would have to remove the sound deadener on the underside of your hood to do this, if it's still there). If you cant find original cushions for your louvers, I would do some experimenting and perhaps use some rubber washers or something similar under the louvers. Also, when tightening the nuts for the louvers, don't tighten them too much because the plastic studs break easy with age. Just snug them enough so the louvers are not loose.
Old Feb 6, 2012 | 12:23 PM
Engine: 305 V8
Axle/Gears: Posi
Alright thanks guys! Ill post a picture of the fished product! Oh and no one ripped them off (id kill them) They both flew off on the highway :/
Old Feb 6, 2012 | 02:10 PM
TheEndofanEra's Avatar
Car: 92 Camaro RS, 93 Caprice Classic
Engine: 3.1L V6, 5.0L V8 + 700r4 on both
Transmission: Rebuilt 700r4 in the Camaro
Axle/Gears: Stock with 3.23s ...3.73 later?
Actually they have those nuts brand new with the RTV sealer ring on them already, if I recall it was about 10 bucks for 50 of them. Just bolt on and go lol
Old Feb 6, 2012 | 02:54 PM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
were your old louvers not tightened well enough?...or were you topping out and they rattled loose?
Old Feb 22, 2012 | 02:48 PM
Engine: 305 V8
Axle/Gears: Posi
They were just old and not secure. Bought the car like that.
Got some new ones on an i made sure they are secure.
Old Feb 23, 2012 | 10:28 PM
Meechyhxa's Avatar
anyone know where i can get a pair of louvers at ?????????????????????????????
Old Feb 23, 2012 | 10:44 PM
AKcamaroAK's Avatar
Car: 1986 Chevrolet Camaro Z28
Engine: 350 V8 4bbl
Transmission: Automatic 700r4
Axle/Gears: 2.73 Open Diff
www.hawksthirdgenparts.com has them
Old Feb 23, 2012 | 10:53 PM
Meechyhxa's Avatar
thanks..
anyone know anywhere cheaper.???
Old Feb 23, 2012 | 11:45 PM
AKcamaroAK's Avatar
Engine: 350 V8 4bbl
thanks..
Probably could find a cheap pair off of a wrecked parts car on craigslist, or go to some local junk yards and ask. try ebay as well, not sure how much they'll have but obviously it's worth a shot. Good luck man.
Old Feb 24, 2012 | 01:30 AM
Meechyhxa's Avatar
thanks alot bro..
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
