Bedliner?
Old Feb 6, 2012 | 08:22 PM
formula_355's Avatar
Bedliner?
I am looking to undercoat my firebird this spring and I was thinking some roll on bedlinen like herculiner would work great. Ihave to patch one rust hole, and I was hobnail coat the inside of the pans too. I have searched but not found many pictures. Has anyone done this that would like to share pictures or give me any advice or other products to use. What would I do about going around brake and fuel lines? Should I just coat the pans and the wheel wells? Should I go around bolts I would need access to? Just looking for some advice. Thanks!
Old Feb 7, 2012 | 07:07 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Re: Bedliner?
Bed liner is a fine idea for the bottom. Stripping it is a pain should you need to make changes or improvements. Remove the bolts, remove the lines, remove anything you can.
Old Feb 7, 2012 | 05:48 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: Bedliner?
i used bed liner on my floor for rust proofing before i installed my new to me carpet.it did take a couple of weeks for the smell to go away.
transaero
Jun 19, 2015 05:34 PM
MikeDirntRulez
Southern California Area
Jan 23, 2007 10:38 AM
nelapse
Jul 10, 2006 08:30 AM
