HOLE IN MY A PILLAR
Old Feb 22, 2012 | 11:10 AM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
HOLE IN MY A PILLAR
One nice rusty hole courtesy of the previous owner (pic attached). any one have any ideas on how to fix this? best course of action ect...???
please feel free to share. my GUESS is I'll have to cut and weld, but i hope not!
Old Feb 22, 2012 | 01:36 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
Re: HOLE IN MY A PILLAR
63 views and no one knows how to fix my hole. ;(
Old Feb 22, 2012 | 01:50 PM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
bondo or epoxy
Old Feb 22, 2012 | 02:14 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
You'll hafta grind it down & see just how deep/thick it is, because you can't decide on what it will take to fix it.
And no, you cannot just slap more bondo or exopy on & expect it to be fixed good. That is just a recipe for it popping out within 6 months.
Old Feb 22, 2012 | 02:28 PM
88gta6spdvert's Avatar
Car: 99 3000gt 88 gta vert 88 gta h/t
Engine: v6 /5.0 /5.7
Transmission: at/5 speed/at
Axle/Gears: ? /3.45/3.23
hello, damn I have one in same spot on 88 gta hard top? confusing me how It got there It was there before I got it not that bad just bubbles in paint. I would just grind it out and fill it with lead man bondo wont hold long flex point on car there.
Old Feb 22, 2012 | 02:35 PM
Eagle223usa's Avatar
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
Grind it down, Cut out the cancer and weld in a patch. That piece is structural...
Old Feb 22, 2012 | 03:17 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
this is what i was thinking. i should probably pull the the glass too.
Old Feb 22, 2012 | 04:03 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Yes pull the glass. Otherwise you won't know if there is additional damage under there.
Old Feb 22, 2012 | 06:55 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
i assumed he knew what to do before just slapping it in
Old Feb 22, 2012 | 07:37 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
I have been looking for an excuse to buy a welder anyways. as i delve deeper into this car im finding serious issues under the t-top gaskets.
Old Feb 22, 2012 | 09:28 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
The A pillers are filled with foam from the factory.
The foam holds moisture and usually rots from the
inside out.
Grind and cut out the rust, braze in a new metal patch or just bondo or lead over the hole.
Old Feb 23, 2012 | 06:04 AM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
foam...lol. WTF was the general thinking. i love the 80s but sometimes i have to wonder. oh well, a grinding i will go.
Old Feb 23, 2012 | 08:19 AM
nosajwols's Avatar
Car: 82 Z28
Transmission: TH350 for now
Over the last 20 years I have patched this same spot a few times. The last time we pulled all the foam out (IMO it is the main problem). We also spayed the entire inside of the pillar with chassis saver.
Old Feb 23, 2012 | 02:57 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
i might be wrong, but it looks like there is body filler already on the a-pillar. is this factory? i wouldn't think so. but you never know, they did put FOAM in the a-pillar.
Old Feb 23, 2012 | 05:05 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I believe it was for sound deadening. The only reason it would cause a problem would be due to water seeping into the a-pillar from somewhere else. Since it's a t-top car I'd suspect a rusted seam or hole higher up, possibly hidden beneath a weather strip. Removing the windshield is a good idea, chances are theres some rust somewhere around the window channel. With that kind of rot at the a-pillar I'd take a good look at the floor pans, spare tire well, around the rear window, under the rear bumper cover, ground fx (pinch welds and fender drain area) post more pics if u can, a welder is a good investment with our cars
Old Feb 24, 2012 | 06:08 AM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
welder is a definite must. this particular hole, according to the PO, was caused by a truck backing in to the mirror and snapping it off into the a pillar. is this the truth? i don't know.
Pac J
May 17, 2020 10:44 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
drumstixer
Sep 29, 2015 03:02 PM
