Access hole in hatch bump
Car: '85 Pontiac Firebird
Why the hell do people hack up these cars to get access to the gas tank?second question. how do i fix this short of matching up anti-bodyflex grooves, and welding another piece of steel on top?
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Re: Access hole in hatch bump
They do it to change out the fuel pump quicker. Not so bad if done right if you ask me. Its the ones who just hacksaw the panel to get to the pump and leave it as is that cause this "mod" and the people who do it right, to get such a bad rep. If you dont like yours, just weld it shut.
Car: 1987 Trans Am
Engine: LQ9/L92
it may be easier to cut out an oversized section from a junked car to weld in place. less custom sheet work needed.
the access hole is good in theory, usually pretty bad in practice though. not to mention the design of our sending units make doing a clean setup difficult. would be perfect for anyone doing a 4th gen tank swap though...
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I got my car with it done. I dont ,imd it as it was done clean and not tooo big. The panel is riveted in and If I ever needed to change the pump quick. It will be a hell of alot easier then pulling the tank when its full as I like to make sure my tank is full on any vehicle I own all the time. Never know when you will need the fuel if something happens. If it wasnt done to my car already Im not sure I would do it to it. If I did I would do it so it was like the honda set up for sure. Might even look for a plate like that the next time im at the wreck so I can replace mine. I do have a 4th gen tank too if that matters
1Aauto
Sponsored Vendors
Sep 23, 2015 01:09 PM
1Aauto
Sponsored Vendors
Sep 23, 2015 01:00 PM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
Glowsock
Sep 5, 2015 07:48 PM
