4" cowl hood questions
Old Feb 25, 2012 | 12:19 PM
Badrs2810's Avatar
Car: 91 camaro rs
Engine: 305 (350 vortec in dec.)
Transmission: Wc-T5
Axle/Gears: 3.08 (3.42 in dec.)
I have a 91 camaro with a 4" cowl hood (fiberglass), I went to use the stock hood bolts, as I did on the same kind of hood on my 92 camaro, only issue is the stock bolts are too small. Anyone else have this prob? My bolts are 6mm but I can slide it in and out with no prob, 7mm screws in but it's a flat bolt, not tapered like the hood bolts are supposed to be. If anyone has had this issue, what bolts did you use and where could I find them, thanks. Btw: this is my hood:
Old Feb 25, 2012 | 12:26 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 4" cowl hood questions
tapered bolts?
Old Feb 25, 2012 | 12:44 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
Idk if tapered is the word, here's the stock bolt:
But it's 6mm, doesn't grab, I need a 7mm
Street Lethal
Apr 30, 2019 12:14 PM
LittleFranks
Aug 20, 2015 03:55 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
