Paint code for ground effect
Old Mar 11, 2012 | 01:31 PM
Heitzman's Avatar
Car: 1983 Z28 Camaro H.O.
Engine: 305 H.O.
Hello everyone, I have a 1984 Z28 Camaro I am redoing. My question is what is the paint code for the silver ground effects on these Z28's? Thanks
Old Mar 11, 2012 | 04:24 PM
trashcanty's Avatar
Car: 88 camaro
Engine: 2.8
Re: Paint code for ground effect
I believe the code is wa7448. Check you body tag on the car to make sure that is right. It should be on your drivers side door or in your glove box or by your spare tire. It will be down towards the bottom of the sticker, you will see a number with a U, "stands for upper" and L "lower". Hope this helps
Old Mar 11, 2012 | 04:33 PM
Heitzman's Avatar
Engine: 305 H.O.
This is the code at the bottom wa-u3967-L3967-a8653. does that sound right?
Old Mar 11, 2012 | 04:52 PM
trashcanty's Avatar
Car: 88 camaro
Engine: 2.8
I own a paint business and ran your numbers, wa 3967 = arctic white, 8653 = Dark Goldwing Met. The colors sound right as long as it is the org. paint and not repainted
Old Mar 11, 2012 | 05:27 PM
Heitzman's Avatar
Engine: 305 H.O.
so youre saying the paint code says the ground effects should be gold? I think someone has changed out the console arm rest. I am coming up with paint codes PPG3308 and DUPLI-COLOR GM301 or DSGM 503 on line. no signs of my Z28 being repainted, i am the second owner an its all original. does this sound right?
Frozer!!!
Jan 19, 2024 04:55 PM
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
mikey8494
Aug 22, 2015 07:57 PM
92firebirdchris
Aug 14, 2015 11:56 AM
