ignition actuator rod not working right?
Old Mar 16, 2012 | 11:09 AM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
Ok, so here's what's going on. I've been working on getting my car going, and I have been having a lot of trouble with the ignition actuator rod in my steering column. whenever I turn it to acc, and then try to start it, the key just flops around. I figured out that for some reason, the rod that hooks up inside the column will come off of where it's connected to if you put it in acc. for the most part it was just annoying, but now I've also been having trouble even when the car is just off and I try to start it. It just slips off of whatever it hooks to and won't work unless I reach under the column and wiggle the rod back into place on the column. any idea how to fix this, or even what might be causing it?? Is this even a clear enough explanation? I barely understand the steering column, so I'm probably not being as clear as I could be on all this. But any ideas would be GREATLY appreciated at this point.
Old Mar 16, 2012 | 02:07 PM
Patrick Day's Avatar
Re: ignition actuator rod not working right?
Sounds like the switch that the rod atatches to is worn. not at the key ignition switch but the switch in the column itself.
Old Mar 16, 2012 | 05:54 PM
fervernt's Avatar
yep thats what I was afraid of. I ended up taking it back to the shop that fixed the loose wheel. hopefully they can fix this too.
BRoss99
Aug 10, 2025 05:08 PM
1992rs/ss
Jan 31, 2025 05:10 PM
Out-Cast
Mar 22, 2019 09:39 PM
9192camaro
16
Feb 3, 2019 12:21 AM
justin57
Aug 20, 2015 07:05 PM
