Colorsanding
Old Mar 23, 2012 | 12:03 AM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Colorsanding
Forgive my noobish-ness.
I finished spraying my car with a single stage paint.
I have runs in about three areas (the paint was black and part of the car was in the shade, so I couldn't see the paint hitting. )
There is also orange peel everywhere.
What grit should I use to colorsand the runs out? Then, what should I use for the orange peel?
Old Mar 23, 2012 | 06:48 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Re: Colorsanding
Start with 600 for the runs only. If your real careful you can shave the top with a razor blade like this. If you're unsure of yourself, then don't, use the 600 with a rigid straight edge to address the runs. If there's enough paint on the car, start with 1000 and work your way up to eliminate the peel.
Old Mar 23, 2012 | 07:49 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
Re: Colorsanding
tape the two edges of a razor blade with a single wrap of masking tape. scrape the runs down holding the razor at a 90* angle. once you have the run scraped down hit it with 1000 grit then 2000 grit. i wouldnt go anything lower that 1000 grit. it doesnt take much to sand through. make ABSOLUTELY sure that the paint is dry. if you try while the clear is still soft youll have big problems.
Old Mar 23, 2012 | 11:24 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Colorsanding
Wet sanding and a buff will do the trick also.
Old Mar 24, 2012 | 12:00 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: Colorsanding
He said he used a single stage, not basecoat/clear...
Old Mar 24, 2012 | 08:16 AM
Car: 84 camaro Z28
Engine: 434sbc
Re: Colorsanding
the method that i wrote above will work on any non metallic single stage or any base/clear. always use a block when sanding and buff it out after you hit it with 2000grit. with it being black you will always see a shadow of where the run was. so the only way to completely eliminate it is to repaint that panel.
Old Mar 24, 2012 | 09:21 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Re: Colorsanding
Thanks for the advice guys. I only have four coats on. I'm too scared to use 600, but the 1000 seemed to work fine, it just takes a long time.
58mark
Sep 23, 2011 04:50 PM
prostock700
Jul 12, 2010 10:19 PM
sam24th
Members Firebirds
Feb 28, 2010 09:24 PM
58mark
Jan 28, 2010 05:45 AM
garry90z28
Mar 11, 2008 01:04 PM
