Seperating Tail Light Housing
Old Mar 30, 2012 | 02:54 PM
Adrenaline1's Avatar
Car: 1982 Firebird
Engine: 2.8 N/A
Transmission: Manual 4 Speed
I have a set of the grid style firebird tail lights and need to separate the front half from the back half and i dont know how. It looks somewhat straight forward but these things are just plastic so id rather not start prying things and break parts. Any help would be greatly appreciated. Thanks
Old Mar 30, 2012 | 04:38 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Seperating Tail Light Housing
I don't think they come apart!!if you want to clean them,I poured some bleach and water in the light hols and shook them up and it did a real good job.
Old Mar 30, 2012 | 04:56 PM
Car: 1982 Firebird
Engine: 2.8 N/A
They certainly do come apart, theres even a gasket like material between the back part and the lens. Im not trying to get them apart to clean them but thanks for the advice.
Old Mar 30, 2012 | 05:09 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
I've taken the grid style, 87-90 GTA, lights apart & they are actually pretty easy. I did it when I converted my clear Reverse light lenses to Red lenses & tied them into the Tail/Brake lights.
Pull the top 2 plastic pins out. Most likely they'll break & I've just used small sheetmetal screws to hold them back together. They bottoms are "hinged".....Tab into slot.....and to get them apart, I've always just pulled those pins then used a butter knife & a razor blade/X-acto knife. GENTLY pull apart & use the blade to cut the adhesive.
Just takes time, patience & warmth. I've never bothered to heat mine up any, but I wouldn't try it in the winter while it is still cold, unless you use a hair dryer/heat gun.
Old Mar 30, 2012 | 05:16 PM
Car: 1982 Firebird
Engine: 2.8 N/A
Yeah i can tell those plastic "pins" are gonna break no matter what. Ill try again and let ya know what happens. lol
Old Mar 30, 2012 | 05:29 PM
Car: 1982 Firebird
Engine: 2.8 N/A
I got them apart, they were stuck together pretty dang good. lol
Old Mar 30, 2012 | 06:41 PM
mantaguy's Avatar
Engine: 5.0 EFI
Thanks Blackened,that's good to know!!I learn something everyday.
Old Mar 30, 2012 | 06:46 PM
mantaguy's Avatar
Engine: 5.0 EFI
I actually changed out my left side on Monday,the grid looked like it kinda slide down like it melted or something only the one side,wonder why.
Old Mar 30, 2012 | 06:53 PM
Car: 1982 Firebird
Engine: 2.8 N/A
The grid itself is part of the outer housing so i dont know why it would look like that unless there was some serious delamination. With the housings apart it seems like it would be pretty easy to fix a little delam though.
Old Mar 30, 2012 | 06:57 PM
Car: GTA
The grid delamination is a common problem for those lights & nobody has ever fixed one, to my knowledge. Also why I have 2 spare sets!
If you know how to fix it, other than Super Glue os something like that.....Fill us in!
Old Mar 30, 2012 | 06:58 PM
Car: 1982 Firebird
Engine: 2.8 N/A
Whats wrong with super glue? lol
Im gonna try and figure something out.
Old Mar 30, 2012 | 07:03 PM
mantaguy's Avatar
Engine: 5.0 EFI
This is what happened to the left side.
Old Mar 30, 2012 | 07:06 PM
Car: 1982 Firebird
Engine: 2.8 N/A
Yep, thats delamination. Its the grid seperating from the clear lens.
Old Mar 30, 2012 | 07:11 PM
mantaguy's Avatar
Engine: 5.0 EFI
I'm gonna try to get them apart,I see the clips on the bottom,took them off and what did you use to remove the pins?
Old Mar 30, 2012 | 07:14 PM
Car: GTA
I forgot about those clips. Been years since I too mine apart to convert the clear to red & I forgot about those clips. I think I used wire cutters to get under the edges of the pins & a flat blade screwdriver for the clips..
Old Mar 30, 2012 | 07:16 PM
mantaguy's Avatar
Engine: 5.0 EFI
I'm gonna give it a shot!!
Old Mar 30, 2012 | 07:17 PM
Car: 1982 Firebird
Engine: 2.8 N/A
I forgot the clips at first as well. lol
To get the pins out i just used a screw driver and needle nose pliers. The pins were shot. lol
I was wondering why your reverse light covers were red. Is that legal? I thought they were clear for a reason.
I took these housings apart to install my LED tail lights, they look great.
Old Mar 30, 2012 | 07:30 PM
Car: GTA
Reverse Lights aren't required items here in Texas.
But I wanna hear about your LEDs once they are in & a pic/video of how bright they are & how they light up the lenses. Like a "spot" of light or fully light the whole lens part. I wanna do LEDs for my Sequential Turn Signal lights.
Old Mar 30, 2012 | 07:33 PM
Car: 1982 Firebird
Engine: 2.8 N/A
Theres a lot of LEDs on these boards so id assume the whole thing will be lit up pretty well but only time will tell i guess. Im testing them out to get feedback from you guys on here so if you want to see anything in particular just lmk.
Old Mar 30, 2012 | 07:43 PM
mantaguy's Avatar
Engine: 5.0 EFI
Got it!! not bad pretty easy,those pins,they are just a cap that pushes into a wall anchor type pin.
Now that I got this apart,what do I do with it? apparently the grid can't be fixed.
Old Apr 3, 2012 | 07:48 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
i used weatherstrip sealant chalk
Old Apr 3, 2012 | 08:04 PM
mantaguy's Avatar
Engine: 5.0 EFI
No,I meant what will I do with it,the grids no good!!!,I guess I can hold on to the guts.
Old Apr 3, 2012 | 08:06 PM
Car: 1982 Firebird
Engine: 2.8 N/A
Try different things on it to see if you can make it look better, thats what im gonna do.
Old Apr 3, 2012 | 08:12 PM
KITT1983's Avatar
oh i meant use weatherstrip adhesive for sealing and gluing the housing back to together
Old Apr 3, 2012 | 08:25 PM
mantaguy's Avatar
Engine: 5.0 EFI
If I tinted the grid,would you be able to see the grid the way it is.
Frozer!!!
Jan 19, 2024 04:55 PM
Jk_Under
Sep 2, 2015 10:59 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Omega
Aug 10, 2015 12:46 PM
