91-92 camaro ground effects
Old Apr 9, 2012 | 08:42 AM
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
Hey guys,
Can anyone tell me if 91-92 camaro side ground effects will fit on my 1982 trans am. I am going to pick a set up tomorrow. I like the look of them a lot better the whats on my car now.
Old Apr 9, 2012 | 10:34 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: 91-92 camaro ground effects
From what I have heard they need the side pieces that are welded to the rocker. I have never confirmed it but a few people have said you need them
Old Apr 9, 2012 | 01:34 PM
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
Really wow, I didn't think about that. So the rockers are different on the camaros then!
Old Apr 9, 2012 | 02:24 PM
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
Anyone else know if this is the case?
Old Apr 9, 2012 | 03:11 PM
6SIX6's Avatar
Car: 89 IROC
From what I was told its only the brackets welded on. There have been tons of people that have put it on their car so theres got to be a way without that piece
Old Apr 9, 2012 | 05:57 PM
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
Do you know if the brackets are on the ends of the rockers. Maybe people weld new brackets on to make them work. It would be nice to see a pic of these brackets, or here from someone who did this.
Old Apr 9, 2012 | 07:56 PM
TheEndofanEra's Avatar
Car: 92 Camaro RS, 93 Caprice Classic
Engine: 3.1L V6, 5.0L V8 + 700r4 on both
Transmission: Rebuilt 700r4 in the Camaro
Axle/Gears: Stock with 3.23s ...3.73 later?
The brackets bolt through the back of the front fenders and through the quarter right behind the doors. There's also a support brace spot wielded to the rocker under the doors on my '92. I think there's some pictures of the support a least on my cardomain, just click my sig picture (shameless plug :P )
Old Apr 9, 2012 | 09:12 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
There is no way no how camaro ground fx are going to bolt to your TA and look anywhere near right. I'd be shocked if you could botl them up at all.
Old Apr 9, 2012 | 10:41 PM
Seeing as the camaro and firebird are, on the frame level, identical there's no reason for them to not have interchangeable ground effects. Actually, I've seen a T/A or two on here with IROC rocker ground effects. All that would be required should be some mounting hole modification, if that.
Old Apr 10, 2012 | 06:37 AM
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
Thats what I was thinking, the cars are pretty much the same. I only want to mount the sides. I will use my front and rear ground effets.
Old Apr 10, 2012 | 08:51 AM
Car: 1992 Camaro RS
You will have to buy a Camaro Hood, fenders, bumper cover, and ground fx to make it work. Which means all new lights too.
If you just want to find some way to attach it and "force" it, then that's one thing. But to mount it like the factory, and have it look factory, the TA's have a completely different nose and fenders that wont facilitate that. Ground fx dont mount to the frame, they mount to the fenders and bumper cover etc.
But if you want to try, go ahead.
That said, it would be fairly easy to put the side skirts on there.
Old Apr 10, 2012 | 10:07 AM
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
Thats all I want to put on is the sides I don't want to do anything to the front and rear. So the sides will work then?
Old Apr 10, 2012 | 12:22 PM
I am 99% sure the side skirt ground effects that go on the rockers under the doors will work fine as that part of the car is the exactly same (sand mounting holes) between camaros and firebirds from 1982 through 1992.
Front and back ground effects are not the same between camaros and firebirds and thus are not interchangeable, as InfernalVortex said.
Old Apr 10, 2012 | 01:18 PM
Car: 1992 Camaro RS
Just make sure you get the door pieces too.
Old Apr 10, 2012 | 08:00 PM
Sorry if I came off as an *** there haha. I don't know what that was about
Old Aug 3, 2012 | 09:02 AM
fyrebird68's Avatar
I am going to pick up a door from a Camaro to repair my TA. Does anyone know if the ground effects holes in the door are in the same places Camaro vs Trans Am?
Frozer!!!
Jan 19, 2024 04:55 PM
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
GVMV
Aug 16, 2015 07:08 PM
92firebirdchris
Aug 14, 2015 11:56 AM
