84 camaro, popping noise when taking off
somebody tell me what this noise could be. whenever i take off from a stop, there is a popping noise from my passenger side front wheel area. there are no sway bar end bushings there so could this be causing it? or is it something more serious?
Car: 1983 Recaro T/A / 1988 GTA
Engine: 305ci Crossfire LU5 / 305 TPI LB9
Transmission: 700R4 / T5
Axle/Gears: 10 bolt posi 3.23 /
Re: 84 camaro, popping noise when taking off
Mine is doing the same thing, I believe its the strut tower bearing plate.
Car: 92 RS
Engine: L03 with Holley Sniper EFI, headers
Transmission: T-5, hurst billet shifter
Axle/Gears: 3.08 posi
I had something similar a few years ago after getting some transmission work done. I took it back to the shop and there were some bolts that had come lose which they re-tightened.
Car: 1986 trans am And a 1997 tahoe 4x4
Engine: 383
Transmission: 700 r4
Axle/Gears: 373
your end swaybar bushings need replaced my trans am done the same thang in one was missing on mine so i replaced mine in it dont pop any more
theshackle
Sep 17, 2020 08:26 AM
db057
Aug 11, 2015 10:11 PM
