Aerosol clearcoat
Old Apr 28, 2012 | 10:25 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Aerosol clearcoat
Have any of you tried using aerosol clear to restore areas where the factory clear has worn away? I'm looking at buying an 88 Formula for my nephew and the car has decent looking paint from the roof rail down, it's just the roof that's bad. I'm thinking maybe I could spray the roof with this clear, then wetsand it smooth. I know it won't look perfect, but I don't want to spend a fortune on paint until I know he'll take care of the car.
http://www.repaintsupply.com/pd_2_part_2k_aerosol.cfm
Old Apr 28, 2012 | 10:34 AM
Damon23's Avatar
Car: 1992 Z28
Transmission: 5 speed
Re: Aerosol clearcoat
I often wondered the same thind as I have a very small spot on my rear bumper.
Old Apr 28, 2012 | 10:53 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Well I've always noticed in areas where the clear has eroded away, if you wet it with a water hose, it looks deep and shiny again. This is kinda the same concept I guess.
I remember years ago they made this stuff that was acrylic and it came with a special sponge applicator. You could put that stuff on faded paint and it instantly deepened it up. I can't remember the name of it though.
Old Apr 28, 2012 | 11:24 AM
TheEndofanEra's Avatar
Car: 92 Camaro RS, 93 Caprice Classic
Engine: 3.1L V6, 5.0L V8 + 700r4 on both
Transmission: Rebuilt 700r4 in the Camaro
Axle/Gears: Stock with 3.23s ...3.73 later?
I've used some before when I was deciding what color to paint my car. I got a can of it and three samples of PPG basecoat and sprayed them all on an old fender. It worked well, not near the depth and gloss of a real high end clear, but it'll certainly work for a touch up, especially if it's a 2k style. It'll bring back the shine real well, just feather the edge where the old clear ends with some 1000 grit and spray away!
Old Apr 28, 2012 | 04:25 PM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Please remember, half-a$$ing it now will most likely cost a fortune later. It will all need to be stripped for the "good" stuff to adhere.
That's putting it mildly.
Old Apr 28, 2012 | 04:56 PM
If its a real 2K in that rattle can (eg. Has a time limit after activating) -which it probably is- it won't be halfassing it cause it'd be like using PPG's omni clear. Cheap but miles better than the best crap clear you find in wally world.
And the original clear at least would have to be sanded off anyway before doing it right, so this wouldn't be anymore work and it wouldn't even gum up the paper because it'll chemically harden.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Catcher55
Aug 15, 2015 07:08 PM
Mike89GTA
Nov 22, 2001 09:47 PM
Jed
Aftermarket Product Review
May 21, 2001 10:32 PM
