How do you get the friggen ground effects off???
Old Oct 15, 2000 | 04:05 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
I'm trying to touch up a couple of rust spots that extend under my ground effects on the drivers side, and I can't get the rocker-panel extensions off!! I took out all the bolts on the underside, as well as all the bolts inside the door sill.
Are there clips I'm missing?? How do I get these off? Thanks for any help you can give!!
Jason E
'89 RS
Jason E
'89 Camaro RS 2.8
Grey/AT/T-tops/all power
Hypertech chip/2 K&N filters/Accel 8.8 wires/RapidFires
Eclipse CD and 100x4 amp/Boston 746 4x6 plates and RX 6x9 3 ways/ALL Monster's goodies
Alpine Alarm w/ Keyless entry
IROC tailights/t-windows
Old Oct 15, 2000 | 04:43 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Jason,
There are two screws underneath the "RS" emblem and one nut on the rear of the rocker that's keeping you from removing them.
The best way to remove the emblem is to jack the car up and look up towards the emblem from the space between the rocker and the body. It's not easy but you should see two black plastic studs. These hold the emblem in place. With a long screwdriver, slowly push on the studs. Once you've pushed them out about 1/8-inch, you should be able to grab the emblem and pull it out. If you don't do it this way and try to pry the emblem out from the front side, you will chip the paint on the rocker. The two self-threading screws are under the emblem.
The nut that holds the rocker on the rear is accessed by removing the rear plastic interior armrest piece. There will be a piece of rubber about 4" x 4" glued to the body. Remove it and you should see an 11-mm self-threading nut. Remove it and the rocker should pull off the car.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
12.57 @ 111 mph.
12.04 @ 114 mph (50-hp nitrous).
http://www.ozemail.com/au/jca69/mods/williesz/willie.html
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
lewandom
Oct 1, 2015 08:15 AM
Damon
Sep 26, 2015 04:29 PM
