INFL (Light on dashboard went on)
Old Nov 5, 2000 | 01:20 AM
soltan's Avatar
Hi!
I've got a 1992 25th Aniversary Camaro RS and some light on the dashboard went on.
I do not have the manual anymore, so I cannot figure out what is it's meaning.
It is something with "INFL" in it. Could you please help? What should I do?
Also, is there any special difference in a 92 RS and a 25th anniversary RS? do both have 170bhp?
TIA
Old Nov 5, 2000 | 01:23 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not sure, but I think INFL refers to your inflatable restraint, a.k.a. your airbag.
1984 Silver Z28, 383 cid 4 bolt, ARP Fasteners, 2 1/2" Cowl Induction Hood, 600 cfm Performer Carburetor, Torker II Intake, Performer RPM Heads, XE268H Cam, Magnum Roller Tip Rockers, MSD6AL Ignition, Blaster2 Coil, Recurved HEI Distributor, 700R4, TransGo SK, 2.73:1 Limited Slip Dana 44, Terminator Headers, Custom 3" TIG Welded Stainless Exhaust, Flo-Pro Twister Muffler, 4 Wheel Disc Brakes, Oil Cooler
Old Nov 5, 2000 | 10:00 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Yes , that is your air bag sytem telling you its got a problem.
When the light is on the system will usually disarm itself until it is fixed.
I wouldn't go whacking any other objects until its repaired.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Nov 5, 2000 | 10:25 PM
soltan's Avatar
Thanks, guys.
Where do you think I should go for repairs?
Is it costly? Probably couldn't do it myself.
[QUOTE]Originally posted by Engineboy:
[B]Yes , that is your air bag sytem telling you its got a problem.
Old Nov 6, 2000 | 05:32 PM
jeff's Avatar
Hey, i was just going to post the same problem. i have a 92 bird and the infl. rest. light went on. inflatable restraint. i went to pontiac and they said my airbag was broke and it would cost me $720.00 to get a new one. i was wondering if you could just take the bulb out, because its a bright red light and it hurts my eyes at night. they charged me $40.00 just to hook it up to the machine and tell me the air bag wasn't working, duh. took em 2 seconds. is it possible to take out the bulb?
Old Nov 6, 2000 | 11:36 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
I imagine you could take out the bulb.
I heard/read somewhere that you can also put a resistor accross the airbag plug and trick the system into thinking that there is a working airbag still there.
If I was going to take the bulb out or do anything to the system other than fix it I would sure as he** unplug the airbag.
Any small votage spike from a malfunctioning airbag system could set that thing off. Thats why they usually quit working when it senses that there is a problem with the system.
Could you imagine...driving down the street with your big gulp....cigarette in mouth...hit a bump....when BLAMMO !! (cough, cough, cigarette...stuck in....throat... )
Not that it would happen, but its something to think about.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited November 06, 2000).]
Old Nov 7, 2000 | 09:17 AM
soltan's Avatar
that't fine, man. i guess i just have one more reason to get a normal sport wheel ;-)
i'll figure out the dashlight. i am going to store the car for winter, so i've got plenty of time to work on these details.
thanks anyway
[This message has been edited by soltan (edited November 07, 2000).]
Old Nov 7, 2000 | 04:09 PM
surfer02000's Avatar
I had the same thing happen to me, so I took the dashboard off and took the light bulb out.
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
