84 camaro nose cone not straught...help
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Hello fellow third geners! My front end is really out of whack. Not sure why this is happening. Is this a difficult thing to fix? or is it something I should be able to do easily. I have pretty bad arthritis in my hands so, well this is why I am asking. I don't want to start something I can't finish....here's some pics.
Passengers side
Drivers side
Thanks in advance for any advice.
Passengers side
Drivers side
Thanks in advance for any advice. Last edited by onthedownlow; May 31, 2012 at 01:06 PM.
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Re: 84 camaro nose cone not straught...help
My bumper does the same thing on the corners...the bumper cover just flexes in in those areas making it look off. If you pull it straight you'll understand what I mean. As far as fixing it, I'm not sure. If there is a way I'd love to know!
EDIT: Now that I look closer...looks like you might need to loosen the bolts and just readjust the cover.
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Looks like passenger side cover is not properly on the headlight mounting panel. Sorry about your friend Arthur, he is a pain. So is removing that front cover but it probably will have to come completely off to get the cover in the right place. You may not have to, you could try to loosen it at the fender and push it back in. I've found that some times the covers that are tucked in toward the fenders are low in the middle. Raising the h/l mount panel in the middle a little seems to help a little. Good luck with it, I'll try and help you as much as I can.
84z96L31vortec
Aug 20, 2017 12:16 AM
