Painting Finally!!!
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Painting Finally!!!
Finally painting my car. Hope to be done by the end of june. Gonna get some bumper stripper tomorrow and finish strippin the bumper. I got the left side door and rocker ground effects, and fender vent off to sand either tomorrow or saturday. Also the body molding off to stay off. I'm paintin the factory red color of a 75 trans am. And I'm also gonna shave the antenna. Also on the list, t top headliner, carpet, and weatherstripping. And a bunch of small stuff. Gonna check the bank funds tomorrow and see what all I can order. So stay tuneddd!!!!!
Car: 91' Camaro RS T-top
Engine: 3.1 V6
Re: Painting Finally!!!
Another good idea to do with this project is to use a scuffpad to your tailights and put a clearcoat over em. it will really shine em up. I did that with my old 84 bird. and it looked very good.
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
imma buy a new set, the ones I had were brand new till some jerk busted them, so i just grabbed a crappy set from work, gonna be buyin some nice ones soon
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
my new best friends lol. strippin the front bumper and this stuff works great. Got it from my friends paint shop for 13$ a can, picked up 2. The scraper i got from advanced for 8 bucks. Had 3 metal and 3 plastic razor blades and the plastic ones work great for getting the paint off after you spray it. Just wear jeans, t shirt, closed shoes, not flip flops and basketball shorts cause that crap burns like hell when you get it on you
Car: Dakota 4.7 4x4, Camaro RS puky 2.8
Engine: 4.7,2.8
Transmission: 5speed, auto, auto
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
well made some progress yesterday. got front bumper 90% done, took some pieces off and got em sanded down
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
well got the body work done on the pieces I have took off plus finished the front bumper. Off to finish the body work and primer it all tomorrow night. Also ordering carpet, weatherstripping, fatmat, and trim piece carpet tonight!
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
got insulation (fat mat), weatherstripping (am auto), and carpet (1a Auto) ordered.
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Its a sem flexible primer surfacer. I paid 30$ a quart, gonna finish a few up a lil bit of body work and re prime all of it. Took 1 quart to do that. Got another quart to finish it up. So 2 quarts total
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
sem 2 part bumper filler. Then finished it up and smoothed it w/ keystone 2 part putty and reprimed
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
carpet from 1a auto arrived today.. looks awesome, great quality. And also fat mat arrived
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
weatherstripping arrived. Bought on ebay from am auto. Really great product, just missing a few pieces. Gonna get up with them and get it straightened out.
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
finally got the bumper and tail light panel primed. body work done on rocker and door ground effects, front and rear bumper and one small spot on the fender. Got to block it down tomorrow night and prime it
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
passenger side fender ground effect ordered, decal kit ordered, primer kit ordered, interior door panel molding with weatherstripping on its way. cant wait to get my car back together to get all this stuff out of my room.... front bumper, all the ground effects, weatherstripping, carpet, sound insulation, front seats, some audio stuff, gallon of primer and a quart of hardener. To much stuff and not enough room, still gotta order the t top headliner, exterior door handles, door lock actuators, and door lock switches and now a power mirror switch from 1a. Slowly but surely gettin there. Gonna work on it all day tomorrow so I'm hopin for alot of progress to be made
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Finally got the front clip primed! pic 1- eye lids, pic 2-left side, pic 3-right side.
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
More pictures! Pic 1- half sanded, half primed. Pic 2-half sanded, half unsanded. Pic 3-bye bye antenna!
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Best way to remove front hood vents: Step 1, (pic 1) get a universal drill bit thingy, Step 2, (pic 2) drill out the inner holes, it will drill off about half the stud but will not effect mounting, only drill enough to squeeze the socket in there, Step 3, (pic 3) Now you can take out the 5/8" speed nuts easily and completely drill out the hole so it is the same size as the other one.
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Best way to remove side hood vents, get 4 flat tipped screw drivers, put 2 on the outer edges to slightly lift up, then take the other 2 and push the clips in and pry up, careful they break easy figured this out the hardway, but if they do, you can plastic weld em back together like I did (no pic of it sorry)
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
thanks, I got a question, i ordered the factory decal set, do I put the decals on after i spray the basecoat and then clear over them? Or spray the basecoat, 1 coat of clear, then the decals then more clear? Or just put them on over the clear?
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
just ordered the plastic panel carpet kit from third gen ranch for 63 dollars total durin there fathers day sale! Cant wait for that to arrive
Car: 91 Z28
Axle/Gears: Stock
IMO, that's too big of an area to clear over. My advice would be to paint it then put the bird on after.
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
i dont have the large hood bird. Just the small nose bird, fender and bumper names, and sail panel birds
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
either solid red, or red with gunmetal gray ground effects, my color scheme is red and dark grey/charcoal. I dont really like silver
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Got my decals from phoenix graphix finally, amazing! they came with so much extra stuff!
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
the whole car is in primer besides the jams, also puttin in a new radio tomorrow! went to plug my mp3 player into my old radio and the aux input is shot so gotta spend another 100 tomorrow for a radio and install kit
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Nice GTA, I'm considering buying an '86 t/a from a distant neighbor who lives about 3 blocks down from me has it and its the same body with t-tops and the same wheels its even faded bright red.
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
I wish it was a GTA, I hate those rims. but imma keep em regardless. GM just cant paint, or maybe they just sucked in the late 80s/early 90s. Red definately fades the worse. I love the T-Tops, definatley a must have for me, I dont care if they leak haha
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Got my radio installed. Took all fricken day unfortunately and didnt get anythin done to the car that I wanted to, but owell. Hopefully I'll work on the interior tomorrow, well just get the rear plastic panels carpeted. I have no clue how to tho lol, the only thing I cant do is interior work. So this should be fun.... Any tips?
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
I've got a complete antenna assembly set up, minus the antenna cord (bracket inside fender, 2 pieces on top of the fender, and the antenna) for 15$ shipped and a brand new right side outer door sweep for 15$ shipped.
Car: 87 GTA
Engine: 5.7 TPI
GTA's are a bit more of a pain to restore (door panels, seats, emblems, etc). If I could go back I would buy a regular TA instead of mine. I like your wheels better than my crosslaces.
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Whole car is in primer, gonna wait till I get back from vacation to paint it so I can take everything off
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
well the car is almost completely torn down, workin on the body work, priming tomorrow or saturday, then wet sand, paint and put back together
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Color combo: red is main body color, its off a 75 Trans Am. gunmetal metallic is the secondary color for the ground effects. Its from a third gen
