Shifter plate/letter alignment
Old Nov 22, 2000 | 08:02 PM
nicksL98's Avatar
When you pull the shifter back in my car, it does not indicate the correct gear nuber on the plate.. i.e. overdrive is "N", 3rd gear is "OD", etc. What is the problem and how can it be fixed?
Old Nov 22, 2000 | 10:33 PM
Drew's Avatar
Camaro or Firebird? I can't remember on the Camaro, but on the firebird the gear indicator plate with the markings is adjustable. Disassemble the plate and one or both sides should have some teeth that key into the trim panel, just lift it out and slide it the correct direction and drop it back down. Its self explanitory.
Old Nov 23, 2000 | 09:45 AM
nicksL98's Avatar
it a camaro..is it any different?
Old Nov 24, 2000 | 04:16 AM
Omar's Avatar
The camaro is the same.
1989 IROC-Z 5.7L
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
