Best way to replace door pin bushing?
Old Nov 16, 2000 | 09:08 PM
Geoff BSA's Avatar
Lower driver side pin bushing is missing and the door sags. Picked up a new bushing and want to know the best way to replace it. The spring looks like it could be a problem. Do I need to take the door off?
Thanks!
Geoff Ullmann
San Jose, CA
Old Nov 17, 2000 | 12:19 PM
gregz28's Avatar
Yah, I just did this. You need someone to help you out. Get a floor jack with a 2x4 and padding and put a little bit of lift on the door from underneath. Unbolt the upper and lower hinges. Each one has 3 bolts; the bottom hinge is bolted from the inside and requires the inside panel to be removed to access them. Have a friend hold the door in place; you wont be able to remove the door completely because of the wiring, but you will have enough room to work. Remove the spring and the pin. Installing is a little difficult, you will need to compress the spring enough to get it in place. We used special pliars which were made specifically for this, if you dont have them youll have to find some other way. Try installing the spring first, then pull it out of the way so you can hit the pin in place. The new bushings make a world of difference...
91 Z28, 383 stroker soon
Old Nov 18, 2000 | 08:25 PM
Tony86TA's Avatar
Once you get the bushing an pin in just stop by a body shop. Even if they charge you 5 or 10, it is diff. worth it. Infact I stopped by a shop and they did it for free.
Old Nov 21, 2000 | 04:34 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
These guys are right on the money, floor jack to support the door, etc.
To get the spring back in, I compressed in in a vise, put saftey wire on two sides, dropped it in, and cut the saftey wire. You have to TOTALLY compress the spring to get it in.
Old Nov 24, 2000 | 11:15 AM
ede's Avatar
ede
my way is way better than a floor jack. i tied my ratchet straps (what holds my car to the trailer) from a rafter and made a loop in it for the door to sit in. i could raise or lower the door with the ratchet, plus swing the door with out it falling off, like it would on a jack. it was so easy it scared me.
-=ICON MOTORSPORTS=-
1st & 3rd
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 25, 2015 07:34 PM
BlackTopKing
Aug 19, 2015 12:13 PM
NBrehm
Aug 5, 2015 07:57 PM
