Faulty Amp Gauge??
Old Nov 29, 2000 | 11:45 PM
Bad3rdGens's Avatar
Faulty Amp Gauge??
I have an 89 RS Camaro, and the problem with mine is that the Amp gauge reads about 9-10 amps while running and about 8(in the red)before the car is cranked. I had an 89 Formula a few years ago that that did the same thing except it only did once in a while. I have had the battery and the alternator checked, and they both were fine (on both cars, by the way) I also have an 82 Z28 currently and have had 2 other 3rd gens (83 Z28, 85 T/A) and neither of these cars ever did this. Has anyone else had this problem, and if so, how did you fix it. Thanx in advance.
Old Nov 30, 2000 | 12:41 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
are you sure that it is an ameter? I've never seen an ameter on a third gen. If so, is it stock?
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
Old Nov 30, 2000 | 04:20 PM
Bad3rdGens's Avatar
Stinger, You are right, I should have said "volts". The voltmeter is what I am referring to. It was kinda late when I posted this... Man that looks bad..sorry!!
But anyway, now that I'm on the the same page as everybody else, Has any had this problems. I am referring to stock gauges. Thamx again.
Fanatic1074
Oct 3, 2022 05:57 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
raymondandretti
Sep 27, 2015 06:43 PM
