Saging Doors, How Do You Fix Them
first why do they sag, and if a part is worn, how do you fix it?
-Stell
1988 IROC 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans
, K & N, 160 Thermostat+ Temp Switch, Relocated MAT, Cold Air
-Stell
, K & N, 160 Thermostat+ Temp Switch, Relocated MAT, Cold Air Member
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
The sag b/c they're old, and damn heavy! There is a tool that costs about $60 that you can use to fix them. I think I saw this on "Hobbyist Dan's" website - there's a link from thirdgen somewhere I swear this guy is mcgyver - no offense to moderator mcgyver of course...
89 Iroc-Z LB9 305 TPI auto 2.73 posi:
3" Dynomax "cat" back,K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, 170' thermo, mild ignition mods, synthetic oil, kicker sound system, soon to have 3.73 posi...
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
GMTECH has an artical on his webpage. Its a tool from snap-on, check it out.
aka:15 year old camaro freak
owner of a 91 z28 5.7l camaro
Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Trans Go Shift Kit, 2k Stall, B&M Rachet Shifter, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
more to come....
My 91 Z28
Car: 1990 Formula
Engine: 5.7 liter
go to my site below and click on technical then go to the sagging door article from there...hope that helps
click below to check out MY FORMULA PAGE!
http://www.formula350.com
or click below to email me
astralbaby11@hotmail.com
I have experience...unfortunatly,its a result of bad judgement.
You can fix your doors for $12.95 a piece. Go to The Paddock, Inc. Sorry, dont have site, try a search engine. They do mostly 1st and 2nd gen, but the have a door hinge repair kit. What a difference! All it took was 10 minutes and a freind to help out.
91 Z28, 383 stroker soon
Hotrodboba400
Dec 10, 2019 07:07 PM
