Applying stripe decals around corners?
Old Jun 26, 2012 | 07:01 AM
Hawk312's Avatar
Car: 2001 Firehawk, `86 Trans Am project
Engine: LS1 in both
Transmission: T56 six speed in both
Hi guys...I am trying to apply the stripe decal that goes around the car just above the rocker panels/ground effects on my `86 Trans Am. I am having trouble getting them to conform around the bumper corners. It seems they want to bunch up around the bottom of the decal. Any ideas? Will the hot rag trick work with these? I am using the decal kit from Classic
(Pheonix).
Old Jun 26, 2012 | 11:31 AM
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
Re: Applying stripe decals around corners?
try using a hairdryer to apply a bit of heat to them, should help.
Old Jun 26, 2012 | 11:34 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Do you have them in the correct places? I got mine from Phoenix graphics and if I remember right they were all pre-cut for the specific body panels and had bends in the material to compensate for the corners. They were shaped like hockey sticks for lack of a better description.
Old Jun 26, 2012 | 02:42 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I had the same problem Hawk,I could only get one corner to cooperate with the heat gun.That's the only freaking place I had trouble.When I get my car back from the body shop,I'm taking it to a local graphic shop to have the new set put on.
Are you using the slide stuff that Phoenix has??I only had trouble with one rear corner,you kinda have to pull on the tape and heat as you go around and up on the strip(real PITA) I'm doing all the other decals,I know were they go,just having them do stripping.
z28venezuela
Oct 24, 2015 08:15 PM
thejimsterz28
Sep 30, 2015 08:52 PM
bschmale66853
Sep 30, 2015 08:11 PM
Gordonr1973
Sep 29, 2015 11:59 AM
tattmann
Sep 27, 2015 05:20 PM
