Got mirror with lights, where to wire them?
Old Dec 29, 2000 | 08:25 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I picked up a couple of rear view mirrors with the reading lamps in them.
I got the wires for them with the lights.
I would like the lights to come on when I open the doors or turn on the interior lights as well as come on when I use the switches on the mirrors.
I've seen some third gens with these type of mirrors installed from the factory, where do I connect the wires so that I can get them to operate the way that I described above.
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Leather 96 Camaro SS Seats,
Alpine CD+Changer,Alpine V12 Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
High Speed Run: 157mph
WS6 Trans Am
Old Dec 30, 2000 | 06:17 PM
HAMMER's Avatar
just run the wire under your headliner,tie into your dome lite.It should work like you described, the mirror should have a two way switch on it as well.
Hope I helped........Hammer
1987 GTA,Black&Sinister.
383 ci TPI,700R4, 12 bolt,3.73:1,SSM lift kit,
home-made cold air induction.12.20's,no juice......yet
Old Dec 30, 2000 | 06:49 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Black wire goes to ground.
Orange wire goes to constant 12V power source (find and splice into one under the dash).
White wire connects to the pin switch on the door jamb.
That's it....
Pete
Pete's Place
HiOutput Virtual Racing Team
Old Jan 1, 2001 | 10:21 PM
Zepher's Avatar
Thanks guys.
I have an extra mirror with lights and the wires for it if anyone wants it.
$25+shipping.
Old Jan 2, 2001 | 04:45 AM
Zepher's Avatar
I hooked up my mirror lights. wasn't too hard. took off the overhead console wrong, tried to remove all the screws instead of just the two in the dome light and sliding the console forward. At least now I know how to remove/install the console.
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 13, 2015 12:59 PM
89FormulaMan
Aug 10, 2015 10:01 PM
Omega
Aug 10, 2015 12:46 PM
