Rattles
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Rattles
Front A arm bushings,ball joints,worn front springs,worn struts and strut mounts are just some things you can check. Let us know what you find and Welcome to Thirdgen we will be able to help get your ride fixed. Joined: Oct 2001
Engine: 4++,350 & 305 CIs
Re: Rattles
Swaybar endlinks.
also get some weld on subframe connectors
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
Re: Rattles
These cars rattle alot. After freshening up my suspension, here are other parts that I had to stop rattling and the culprit. A simple fix goes a long way.
Top of dashboard/dashpad: It was a little loose, and it rubbed against everything, I had to tighten it down, and a little lubrication around rubbing parts stopped the noise.
AC Vents: https://www.thirdgen.org/ventfix
Window and Door Rattles: https://www.thirdgen.org/forums/body...servation.html
Ashtray: I took it out and used a dab of glue on each side, and placed it back. I don't use it, so I don't frequently remove it.
TTops- I put armorall on the edges to stop the squeaking.
The door and window was the major problem for me. After I spent time on that it made the ride alot quieter.
