92camaro rs ground effects.. Ugly??
Car: 92 camaro RS
Engine: vortec 350/396
Ive been looking at my ground effects lately and cant decide if I like them or not. Im comparring them to the late 80s rs camaro. Just wantin some of your guys opinions on this. U like the flat clean look or the holes in the ground effects on the early 90s?
Re: 92camaro rs ground effects.. Ugly??
I've always liked the 91/92 style GFX, I think they look way better than the flat style.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
'91-'92 is the best for actual airflow. But I like the look of an '85-'87 base model, if it has to be a 'maro at all, rather than a 'bird.
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Car: 1986 Camaro
Engine: 355
Transmission: Turbo 400
Axle/Gears: Narrowed Ford 9"
I like the 91-92 RS the best. But If I were going to add ground effects to another third gen I would go with the older version. The 91-92 RS ground effects are harder to find or at least they were a couple of years ago.
85-90 should be the easier to find because they wer made for the most years, but after 88? i think all camaros got the same body kits, i think they stoped doing the base models i think u could only buy an RS,z28, or an IROC after 87
Car: 92 camaro RS
I think im gonna stick with the newer style. When the cars painted itll look better but im looking at them while the car looks like ****. Lol.. When I go to paint the car should I removed the ground effects and have everything painted seperately or just leave it all on the car?
Car: 87 Black Irocz28
Transmission: 700r4 shift kit
Axle/Gears: 3:73 richmend axles and eaton gears
I'm removing all ground f/x right now ...I'm taking as much stuff as I can off before it goes to the body shop...I don't need to wast paid hours to remove parts ...
Almost done ...but I could use some help ...the side ground f/x ...I took the screws out ..that you see from the top and bolts from under the car ...but it won't come off ...
Car: 83 Z28
Axle/Gears: 4:11:1
