Hood latch problem
Old Jul 7, 2012 | 04:14 PM
Big Cleatus's Avatar
Car: '84 Trans Am
Engine: 350 Carb
Axle/Gears: Stock but subject to change.
Hood latch problem
So here is my problem, I have an aftermarket fiberglass WS6 style hood. It doesn't line up perfect, but I can line it up perfect with some work. The problem is when I get it lined up, the latch doesn't line up and it won't shut. Should I scrap the latch and go with hood pins? Anyone else have this problem? How would hood pins look on a WS6 style hood?
Old Jul 8, 2012 | 12:18 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Hood latch problem
The latch is adjustable ( the one that mounts to the the core support at least on camaros )
Old Jul 11, 2012 | 07:49 PM
Car: '84 Trans Am
Engine: 350 Carb
I understand that but it is also the pop spring and the lever hook thingy wajja ma call it that don't line up. I don't know the name of the lever you pull to move the hook that catches. It's not the hood release for the cable for the latch its the one at the front of the hood.
Old Jul 12, 2012 | 07:55 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
If you come to the shop I will help you.
http://www.parderby.com/
Old Jul 13, 2012 | 07:41 AM
Car: '84 Trans Am
Engine: 350 Carb
Your in Derby, nice. I will definately swing by sometime. First I need to finish my interior, then get new tires, and then register my car so I can drive it. Might be a week or two.
Old Jul 13, 2012 | 08:19 PM
Car: 91 z28
Transmission: 4L60e
10-4
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
Bert87
Aug 23, 2015 03:50 PM
Randomtask2
Aug 13, 2015 01:57 AM
