JamesC
close
Although I've worked the scratches out of the plastic lens on my console clock, it's still not absolutely clear--I have used plastic polishes and a lot of elbow grease. Any advice?
JamesC
JamesC
Jim85IROC
close
That's pretty much what I did too. Other than 1 or 2 deep scratches that remained, it came out good, but one of the hands on the clock is bent up and is wearing a groove into the plastic. Looks like I'll be performing surgery again next year!
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
You poor guys with the clocks...
j/k. Do you think you could remove it and install a fabricated acrylic one maybe?
Jim85IROC
close
The lense is a molded plastic piece that would probably be a tad difficult to reproduce.
The IROC Homepage
The IROC Homepage
JamesC
close
I like the clock--only 1 of 800 odd in 1985. It works fine--I'm going to add krypton bulbs to it as well as the AC/Heater control and cluster. I thought that I might as well attempt to make the lens as clear as possible in the process.
JamesC
JamesC
irocnroll89
close
- Join DateAug 1999
- Locationpreviously OKINAWA JAPAN,georgia, now new england
- iTrader Positive Feedback100
- iTrader Feedback Score(4)
- Car1989 IROC--1989 T/A
- Engine5.7 TPI in both
- TransmissionW/C T-5 in both
- Axle/GearsB/W 3.27 in both
- Liked:0 Times in 0 Posts
those clocks are sweet, i polished mine up with meguires stuff. Did you you progressive grit to polish the deep ones first? I have a couple, I maybe putting them on ebay
What do you think they are worth??
'89 SHAGGY IROC
L98 7r4, all free stuff,T.E.S.,HOOKER CAT BACK,KYB,ACCEL8.8,JET fan sw. etc.
so much to do , so little money
What do you think they are worth??------------------
'89 SHAGGY IROC
lonsal
close
The console clock can be repaired. I found one in a junk yard but the minute hand was broken. I did some research to locate parts. It turns out Wesclox (the original mfg.) no longer stocks the parts, but has sold all it's inventory to a place called "The Clock Doc" (800) 256-5362. The owners name is Bill. He can repair the lens by milling it and polishing or sell you another. Good luck, Lon.
