T-Top Question?
Old Jan 7, 2001 | 10:33 PM
1989CamaroRs's Avatar
T-Top Question?
one of my plastic t-tops on my 89 camaro was broken and i replaced it with a glass one i got from a camaro in a junkyard(dunno what year it was) so anyway it fits in fine but the lever to latch it only closes half way but it locks in. Were there more than one kind of t-top on 82-92 f bodys of was the glass vs plastic different. Also what would i need to do to make the glass one latch all the way
-Stock Tbi 305 with a lot of damn miles
-Edelbrock Z28 TES Headers
-3 inch Catco High Flow Cat
-3 inch Edelbrock Catback
Stereo
-Pioneer DEH-P4100 cd player
-Polk Dx9 6x9s
Old Jan 7, 2001 | 11:47 PM
Drew's Avatar
there are at least 4 different variations of ttops for thirdgens. Early models had hooks instead of pins and frames around the glass, later models had pins and no frames, and of course the lexan tops like you have. You can try adjusting the tops, there are adjusting screws under the trim panels on the car that you can use to adjust the holes the pins ride in. Your best bet would be to get a matching set and maybe even get the mounting cups off the donor car.
Drew
The lone Thirdgenner of the Apocalypse
predatorman@hotmail.com
My Website
87 Iroc
91 Formula 14.3@98mph
91 RS Convertible
91 Firebird V6
92 S10
98 Grand Am GT
Old Jan 7, 2001 | 11:51 PM
ok well pins with no frames. was there glass in 89?
Stereo
-Polk Dx9 6x9s
Old Jan 8, 2001 | 11:44 AM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Yeah, I have an 89 Camaro, and as far as I know it was all stock. My T-tops were Glass.
Houston f-body Member Page
Home Page (and pics of my car too!)
1989 305 tbi Camaro RS Red/Red
Flowmasters
K&N
"Stock?! Theres nothing "stock" about a stock car."
Old Jan 11, 2001 | 01:01 PM
Pino91Formula's Avatar
, all factory t-tops were the same from 82-92 aftermarket t-tops unsed different latching methods the only thing that varied is when they introduced the lexan tops, i have a sent of 82 glass t-tops from a parts 82 TA i had they fit fine on my 91 , what probaly happened is the handle might have been taken off at one point or another ,take the torks screw out and set the handle to the correct position. it should
Old Jan 11, 2001 | 01:28 PM
the handle can only fit on in one place i already tried
Old Jan 11, 2001 | 02:47 PM
Ok, measure the length of the pins , with them fully extended, see if there is a difference, it shouldnt be , but you never know.
Old Jan 11, 2001 | 03:22 PM
well the pins are slightly thicker than my oringinal ones
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
Penultimo
Camaros Wanted
Aug 20, 2015 08:42 PM
qz6lwp
Aug 20, 2015 08:10 PM
redmaroz
Aug 16, 2015 11:40 PM
