Source for T-top seals
Old Jan 9, 2001 | 10:31 AM
Fiero_Freak's Avatar
Car: 2014 Camaro 2SS/1LE
Engine: 6.2L LS3
Transmission: Tremec TR6060
Axle/Gears: 3.91
Is there any source in the aftermarket for Seals... I would like to replace all the main ones, doors, ttops, and trunk. I'd appreciate any ideas..
Old Jan 9, 2001 | 01:15 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Soff Seal sells all of the gaskets, and you can get them through Summit as well as a ton of other places.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jan 13, 2001 | 12:21 PM
james's Avatar
Classic Industries has got what your looking for. They don't have a catalog online, but they do have a website.
Old Jan 14, 2001 | 10:52 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
How much dough? I've seen them for big mula.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Jan 8, 2008 | 04:50 PM
weberflorida's Avatar
Car: 1991 Camaro Z28
Re: Source for T-top seals
I would be interested in getting the seal that ends up being over the window kind of like a drip guard. Mine is starting to tear off the ttop.
Old Jan 9, 2008 | 04:51 AM
TA In Progress's Avatar
Axle/Gears: 3.27 BW
Classic industries online catalog.
http://www.classicindustries.com/pdf...ip-molding.pdf
Old Jan 9, 2008 | 07:21 AM
Thanks man I will check it out.
Bill
Old Jan 14, 2008 | 02:18 PM
weinz90's Avatar
Car: 87 IROC, 96 Suburban
Engine: 5.0 TPI, Vortec 5.7
Transmission: T5, Built TCI 4L60E
Axle/Gears: 3.45 posi, 3.73 eaton locker
wow 229.95 thats actually pretty reasonable for all the stuff you get.
Old Jan 14, 2008 | 05:59 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
I just ordered that kit and have heard from others who use that kit that is probably the best out there right now. Considering it has all the t-top car body weatherstripping as well as the pieces that go on the t-top glass part too, it's a pretty good deal. Just make sure you reseal under the new seals and prep it VERY well to ensure it doesn't leak again with brand new seals. I would also use silicone or urethane instead of just the weatherstrip adhesive as you will more than likely want to fill some of GM's gaps where water can get into/under the new seals and leak into the car/cause rust. Urethane would probably last longer before it crumbled or fell apart with time and heat from being baked in the sun. Good luck.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:25 AM
1Aauto
Sponsored Vendors
Sep 22, 2015 03:39 PM
codeysabatini
Sep 20, 2015 11:36 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
