KEYLESS ENTRY
Old Jan 15, 2001 | 08:18 AM
PAformula's Avatar
KEYLESS ENTRY
I want to install an aftermarket keyless entry system in my car. Has anyone done this? If so, Has anyone used the VPA kit from summit? Any info would be helpful.
thanks,
Jason
BLACK 1989 FIREBIRD FORMULA 350
K&N, ACCEL CAP & ROTOR,
FLOWMASTER AMERICAN THUNDER CAT-BACK
Old Jan 15, 2001 | 08:29 AM
cica55's Avatar
as long as you have power door locks it's a joke to do , I've done it several times on different cars and as long as you read the manual , ask questions BEFORE you start cutting the wires and use your head you'll be ok.
Old Jan 15, 2001 | 08:36 AM
PAformula's Avatar
Do you have to remove the door panels?
Old Jan 15, 2001 | 10:40 AM
Neo's Avatar
Neo
Aroound the locks and window controls there are torx screws to undo. I think the size is 5. Be careful there are some fake ones, you to not want to strip those out. Also there is a tech artice on this page.
Mike Kenny
Current: 1991 RS 305 TBI
Past: 1990 RS 305 TBI (A woman forgot what red lights are for)
Current: mostly stock - newer 305 w/ 12,000 on it
Eclipse speakers all around w/ 10" tube powered by a Alpine V12 in back
K&N filter w/XStream flow lid - It is sweet!!
Future: 2" Cowl hood
Old Jan 15, 2001 | 10:51 AM
PAformula's Avatar
where is that tech article? i couldn't find it.
Old Jan 15, 2001 | 07:30 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
You don't have to remove the door panels.All you have to remove is the driver's side kick panel and pull the harness out.There should be a light blue and a white wire which will be the ones you cut to install your keyless.The keyless install manual should have different diagrams for different lock systems.Be sure to use the one for a 5-wire reverse polarity system(usually system "C"), and just follow the instructions.
[This message has been edited by RSpeed (edited January 15, 2001).]
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
i got one from jc whitney for around 30 dollars.wired it into the relay behind the drivers kick panel.it works great!its also has a button for the hatch
Old Jan 15, 2001 | 10:54 PM
jason86/2.8's Avatar
Would you be able to pop the hatch w/ it even if you don't have the button to pop the hatch. I'm thinking about putting a keyless entry system into my car. I have the PDL and after reading this I figure it could be done in no time!!
Red 1986 SC, 2.8L, newly rebuilt 700R4, 3.42 Posi, t-tops, 133K miles and counting, K&N air filters, hopefully more to come!
Old Jan 16, 2001 | 02:18 PM
RSpeed's Avatar
If you don't already have the power hatch release option,then you will need to add a solenoid to one of the extra channels on your remote system.
Old Jan 16, 2001 | 02:51 PM
pianiy's Avatar
RSpeeds got it right... the wires for the door locks are right behind the driver's side kick panel and he's got the colors correct. I installed my own alarm system (real PITA) and that had to be one of the easiest parts to do. BTW, you'll only need to do the one side and it will control both doors. Check out eBay for the remote hatch release or your local junk yard.
~Luke a.k.a. pianiy = drunk (in Ukrainian)
"The world would have no problems if everyone had a presence of mind."
'91 Firebird
305/TBI(L03)/700R4/T-tops
Mods: Catco high flow cat - B&M Shift kit - TA tail light conversion - K&N - MacEwen white faced guages
Stereo: Pioneer DEH-P8200R - Pioneer 6x9's - Kenwood 8" Tube
'87 Firebird
LB8/700R4/220K - Twas a good car until the accident.
Firebird parts - Now with an '80 Firebird for sale!
Moderator of tranny board over at TransAmGTA.com
Old Jan 16, 2001 | 09:11 PM
jichniow's Avatar
Car: 89 IROC-Z
Engine: 6.0L LQ4
Transmission: 4l60e
Axle/Gears: 3.70
Are you guys sure that for a Thirdgen F-body it's a "Type C" or reversed plarity system??
I'm just curious cause I'm going to attempt to install one tomorrow myself, if the weather holds out. I thought that the switch was made to reversed polarity with the 93 F-bodies. I guess I'll need another relay if it's the reversed system.
Old Jan 16, 2001 | 09:46 PM
Omar's Avatar
Yes, for the power door locks, you need to give it 12 volts, NOT a negative ground signal.
1989 IROC-Z 5.7L
Old Jan 16, 2001 | 10:28 PM
jichniow's Avatar
Car: 89 IROC-Z
Engine: 6.0L LQ4
Transmission: 4l60e
Axle/Gears: 3.70
Ok I know that it needs +12V. But is it a low current pulse or is it the reverse polarity type which is a high current +12V and requires additional relays??
I checked the switch on the door of an 89 IROC and it only had 3 wires, which leads me to believe that it's the "Type A" installation which is just a low current pulse. The "Type C" has five wires to the switch.
Electrical Engineers make the world difficult.
Old Jan 16, 2001 | 10:30 PM
RSpeed's Avatar
Yes, I am positive it is a reverse polarity system.I install alarm/keyless entry/remote start systems, and high-end car audio/video equipment for a living( almost 10 years now).As a matter of fact,I just installed an alarm w/keyless entry on my wife's RS lastnight. Just go to the wire harness behind the driver's kick panel and you will find the two wires(light blue and white).
[This message has been edited by RSpeed (edited January 16, 2001).]
Old Jan 16, 2008 | 12:12 PM
Rumblin70SS's Avatar
Car: 88 IROC-Z T-Top car with Bose
Engine: L98 5.7
Axle/Gears: 9 Bolt with 3.27's
Re: KEYLESS ENTRY
Hello all,
I've read the posts above and looked at the tech guide but I still have a question on keyless entry.
Above it says that you cut and use the white and light blue wires in the harness...........when I look at the guide, it says there are three wires, light blue (lock), black (unlock) and white (trigger). Do I do anything with the black wire?
Just want to make sure before I cut anything!
Old Jan 17, 2008 | 11:55 AM
Engine: L98 5.7
Re: KEYLESS ENTRY
Anybody??
Old Jan 17, 2008 | 06:05 PM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
Re: KEYLESS ENTRY
Same Question????
Old Feb 9, 2008 | 06:17 AM
Engine: L98 5.7
Re: KEYLESS ENTRY
Ok guys, I figured this out after getting the car back..................I used the blue and black wires, not the blue and white as stated above. This is with the VPA unit and it works perfectly...............!
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
BlackphantomZ28
Aug 31, 2015 11:19 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
