air bag steering wheel
Old Jan 17, 2001 | 03:49 AM
COUGAR's Avatar
I am going to remove my wheel and trade in for something a little nicer. Does anyone out there have any idea how this is done safely, I would like to keep for resale.
COUGAR
Old Jan 17, 2001 | 10:08 AM
LottaBallsCamaro's Avatar
I have an airbag steering wheel, and I've also thought about replacing it. Do you have trouble honking the horn? I have to press the horn so incredibly hard to get it to work, that it's usually too late to make any difference. Mine is probably just a bad connection, though.
Pretty damn smart with cars for 17!
91 Camaro RS, 305 TBI
No mods yet...Hopefully:
Convert to dual-cat with headers and Borla catback exhaust.
Edelbrock MPFI system.
RAM air hood & Z28 wing.
Z28 cam.
ABS system.
Positraction rearend with rear disc brakes.
Rebuilt front and rearend suspension with polygraphite bushings.
Strutbrace.
Rollbar.
Old Jan 17, 2001 | 10:55 AM
dudelovett's Avatar
I took mine off for a Grant GT. Theres a good tech article about the safe removal of the bag on this site.
1991 Firebird Formula
305 TPI
Auto
K&N Filter
Grant GT Steering Wheel
5% Rear tint
Pontiac Windshield Decal
No real mods yet!
Former owner of an 88 2.8 Firebird....RIP
Old Jan 17, 2001 | 11:34 AM
COUGAR's Avatar
I have no problem with my horn, however I do not trust airbags, so I am removing it. I just found the article this morning, i am not too smart today.
thanks for the info
C
Old Jan 17, 2001 | 11:37 AM
Drew's Avatar
A few things...
The 90 up steering columns are different than the 82-89 columns. For this reason the only factory steering wheels that will fit the 90 up cars are 90 up steering wheels. A 82-89 steering wheel will rub on the column and generally make the car impossible to drive. A grant wheel can be made to work, but I've heard you have to use two of their install kits. The reason the airbag steering wheels are hard to blow the horn is because GM used vinyl plastic that warps with age. Unfortunately the part that warps is the horn buttons. So you get to push it to unwarp the vinyl then a bit further to blow the horn. Also the airbag wheels use the cheapest horn contacts you could possibly imagine. They break easily. On my beater 91 V6 bird the buttons broke and this caused the horn to blow whenever it wanted till the fuse blew.
The only suggestion I can make for a good stock appearing wheel is to find an 88 or 89 steering column and swap the column and use a 82-89 steering wheel.
Drew
The lone Thirdgenner of the Apocalypse
predatorman@hotmail.com
My Website
87 Iroc
91 Formula 14.3@98mph
91 RS Convertible
91 Firebird V6
92 S10
98 Grand Am GT
Old Jan 17, 2001 | 07:53 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
You can use a Grant wheel on a 90-up column. I used only 1 kit plus one washer to prevent rubbing. The horn hook up is the same as with any 82-89 car.
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,no cat,SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit,MacEwen White face gauges,84 T/A cold air induction air cleaner,Grant Formula GT wheel.
Old Jan 17, 2001 | 09:28 PM
dudelovett's Avatar
Yup, a washer did the trick for me too
Old Jan 18, 2001 | 12:59 AM
Mo's Avatar
Mo
my horn is a PITA to use as well
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
1992 Trans Am
May 10, 2023 07:19 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
