? about the "dummy lights"
Old Jan 22, 2001 | 07:44 PM
jason86/2.8's Avatar
On my 86 SC I have the 3 dummy lights (not real gauges) One for temp, oil pressure, and alternator. I was wondering if all 3 are supposed to light up when the key is turned forward but the engine is not cranked. On mine the oil pressure light lights up bright, while the alternator light lights up but about half and bright and the temp gauge does not light up at all. I asked my dad and he said it was prb b/c the engine was cold not overheating. I never thought to pay attention to if they all came on on my friends 85. I just need to know so I'll know whether to tear into it to fix it if I need too. I don't wanna be overheating and my light not come on b/c it's burnt out. I'm not that stupid to not be able to tell if it is overheating but I don't wanna mess up my little engine.
Red 1986 SC, 2.8L, rebuilt 700R4, 3.42 Posi, t-tops, 134K miles and counting, K&N air filters, hopefully more to come!
Old Jan 23, 2001 | 02:30 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I believe that only the oil, charge and check engine lights are supposed to come on just to let you know that they work.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Jan 23, 2001 | 12:33 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
The temp light may supposed to light up when you turn the key to "start". I know the temp gauge shoots all the way up when I turn my key to start. A simple test is also to ground the wire that goes to the temp sensor on the engine. When you ground it with the key in run the light should go on.
Old Jan 23, 2001 | 12:34 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
86 Sport Coupe, 2.8 V6, dead stock, but not for long!
"Little girls play with ponies!"
www.geocities.com/camman86
Rock fans click the secret link on my site!
HoosierinWA
Oct 7, 2015 10:15 AM
Firebird Mess85
Jun 14, 2010 11:33 AM
mike1986fyrbird
Jul 25, 2002 04:53 PM
mikeage2
Feb 10, 2001 06:11 PM
