converting dummy light cluster to 85 mph gauges cluster
Old Feb 9, 2001 | 06:31 PM
mikeage2's Avatar
help!i have a 86 caamaro that used to be a v-6,5-speed car.It has a dummy light dash.How hard would it be to convert it to a gauges dash out of say a 84 z 28?can i just switch gauges and sending units(i know it might require a connector change too)
or do i need to get the whole harness(got the 84 z here ...parting out)
86 camaro:was a v6 car with stick,converting to v-8..NEED A V-8 T-5!!!!!!!!!!email me if you have one!!!
350 cylinders bored .040 over.a little oves 9:1 compression(getting a blower some day when im rich lol)line bored.deck milled a little(was pitted)
trw forged pistons with summit stage 2 polished rods with arp bolts.
194 intake valves,pocket ported,gasket matched,and polished ports,old vette intake with new zinc 650 holley
ase certified for a few years,learned alot though
working on freakin NEONS ,cirruses,tauruses,cobras(wel at least they look nice lol)and intrepids all day makes me drink too much
good job security though
Old Feb 9, 2001 | 06:55 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Just switch the oil pressure and water temp sending units, and plug the cluster in; it'll work fine except for the tach, which will read lower than the engine is turning.
It will read 2000 rpm when the engine is actually turning about 2667 rpm; and 1500 when it is running 2000 rpm.
Pete
EDIT: Doh!!! just realized you are converting to a V8...so the tach from the Z28 will read correctly
Pete's Place
HiOutput Tech Page
83 SC
203+k mile LG4/5-speed
14.935@94.14
[This message has been edited by Petes 84Z28 (edited February 09, 2001).]
Old Feb 10, 2001 | 06:11 PM
mikeage2's Avatar
WHOOHOO thats what i wanter to hear!
thanks pete!!
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
355sbcTPI
Aug 19, 2015 04:38 PM
ChevyZ71
Aug 13, 2015 07:30 AM
