how do you remove the front dash panel...
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
from the '91 Camaro's? I want to replace my gage bulbs with a different color, but how does the front panel come off, and then how do you get to the bulbs?
KAM
KAM
First take away the kick panel from the bottom with torx 30 bit
Then pull off the light switch and the left and remove two black screws that hold the bezel on
Remove wiring (cig lighter, rear def.)
remove 6 silver screws that hold the claer piece on
The take out some more screws at the top of the black piece behind that
Now you should take out the white piece which is being held on by 4 black screws
The bulbs are beingheld in little gray things, these twist out and will make it easier to remove the bulbs
e-mail me withany questions.
Mike Kenny
Current: 1991 RS 305 TBI
Past: 1990 RS 305 TBI (A woman forgot what red lights are for)
Current: mostly stock - newer 305 w/ 12,000 on it
Eclipse speakers all around w/ 10" tube powered by a Alpine V12 in back
K&N filter w/XStream flow lid - It is sweet!!
Future: 2" Cowl hood
Mike Kenny
