Rear Hatch Motor Help
Old Aug 8, 2012 | 10:05 AM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
So my car ate my worm gear so I'm going to get a replacement.
Everything seems to be mechanically fine though... but the reason it ate it is because when it went down.... it didn't stop going down.. or up.. don't remember. What else do I need to look into making sure works before I assemble it and it eats another one? I can afford to be a bit meticulous on this as the car is just sitting idle anyway.
Old Aug 8, 2012 | 11:41 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: Rear Hatch Motor Help
the case. its the clear plastic part the motor, gear and all the other stuff attaches to. its not uncommon for it to be cracked and it can be a contributor to your gear beaing eaten.
Old Aug 9, 2012 | 10:10 AM
waltersb's Avatar
I think in my situation the 'stop'? was getting a bit flaky... it wasn't turning off when it should and then since metal is harder than plastic it just kept turning when it wasn't supposed to and stripped the plastic gear.
Old Aug 9, 2012 | 11:02 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Hatch
Old Aug 9, 2012 | 11:13 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Read the Tech Article I wrote on repairing these hatch pull-down motors. It is under the "General Repair" category. I have all the parts you'll need to repair them.
Lon
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
