Installing weather stripping
Old Aug 10, 2012 | 11:34 PM
actarnoff's Avatar
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
I've searched, and haven't found any definitive answer. I'm planning on replacing all my weather stripping tomorrow with a kit I bought from Hawk's. I can't find instructions on exactly how to do this. I don't want to mess up my new kit; any help would be appreciated.
Old Aug 11, 2012 | 12:27 AM
82tarecaro's Avatar
Re: Installing weather stripping
Here is a good video from fellow member ZZ3Astro on Youtube.
Old Aug 11, 2012 | 06:33 AM
LHernandezJr's Avatar
1A Auto also has a few videos on the subject that may be helpful.
http://www.youtube.com/user/1aauto/v...y=weatherstrip
You may also want to search their YouTube channel for others.
Good luck with your project and post some comments and photos of the process. Those are always helpful to others.
Old Aug 11, 2012 | 08:21 AM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
How much instruction do you need for weatherstripping. Rip the old out and replace with new...very hard to do it wrong, as long as all the clips and screws go back were they belong.
Old Aug 11, 2012 | 08:43 AM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Let me know how yours turns out. I bought a hardtop kit from hawks and it's going to be my sunday job.
Old Aug 11, 2012 | 12:42 PM
actarnoff's Avatar
Engine: 355 TPI
I'll keep this thread updated. I was going to do it today, but it turns out I need adhesive and a heat gun. This will need to wait until Monday.
Old Aug 11, 2012 | 01:00 PM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Did you purchase a weatherstrip kit for a Mustang? What is the need for a heat gun? Quite honestly I'm not sure why you'd need adhesive.
Old Aug 11, 2012 | 01:03 PM
actarnoff's Avatar
Engine: 355 TPI
According to these videos, you need the heat gun to weaken the existing adhesive, and then, I assume, since the factory used adhesive, that I would need to use some as well.
Old Aug 11, 2012 | 01:57 PM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Huh. Mine didn't have adhesive and I believe it's the factory weatherstripping. You may want to give it a try before purchasing a heat gun.
Old Aug 11, 2012 | 02:09 PM
actarnoff's Avatar
Engine: 355 TPI
You just ripped it out and replaced them? The A1 videos indicate you even need to remove the hatch to do the hatch weather stripping.
Old Aug 11, 2012 | 03:30 PM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
I pulled them out without issue. The doors and door frames didn't have any adhesive. My hatch was already off and it appears there was some sort of sticky substance securing the weatherstrip, but it wasn't difficult to remove. Took 10 minutes to remove everything. I haven't installed them as I haven't painted the car, but when I do, I doubt I"ll use adhesive. Maybe a little to hold the ends of the hatch piece, but that'd be about it.
Old Aug 16, 2012 | 03:49 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
Installing t-top or door weatherstripping without weatherstripping adhesive will likely result in leakage, especially the t-tops.
Old Aug 16, 2012 | 05:12 PM
actarnoff's Avatar
Engine: 355 TPI
How do you clean the existing adhesive? I found nothing that cleaned it effectively.
Old Aug 16, 2012 | 05:33 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
I used 3M adhesive remover
Old Aug 16, 2012 | 06:30 PM
actarnoff's Avatar
Engine: 355 TPI
Just looked....doesn't look like I can get that in CA.
Old Aug 16, 2012 | 07:48 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
I had to scrape it off because I was repainting the car. I would try the heat gun method you had mentioned. If there are alot of videos using that method then it should work. The t-top area I would recommend scraping and painting with por15 first to prevent rust. Then you can seal the rubber to it with the adhesive and never see the paint.
Good luck with the project!
Old Aug 19, 2012 | 05:12 PM
Sidethumper's Avatar
Car: 87 Pontiac Trans Am
Engine: Lapouttre Racing 350
Transmission: Rebuilt 700r4 Mild shift kit
Axle/Gears: 10 bolt 3.23 posi w/disc brakes
Go to home depot and buy a 4 dollar 4 inch wire wheel. Put it on a corded drill and the wheel will take it right down to the metal if you want it to.
Old Aug 27, 2012 | 05:32 PM
blakecharles's Avatar
that's what I used to get all the crud out before installing my rear bow seal (convertible). worked flawlessly and took only 3 min
I also used oven cleaner to get the few places the wheel could not reach. it melted all the old adhesive away and wiped off with a cloth. $5 wire wheel from harbor freight + $10 "easy off" oven cleaner
notice the right side has been taken down via wire wheel vs the left (has not been done)
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
I'llrocya
Exterior Parts for Sale
Nov 11, 2015 05:45 PM
g.l.mos
Aug 22, 2015 12:02 AM
