Passenger side window won't go up even. Ends up with window partly open?
Old Aug 11, 2012 | 05:07 PM
Jfinnkma91's Avatar
Car: 1984 Chevy Camaro
Axle/Gears: 7.5in 10 bolt with 3.08
1984 camaro with the manual style window cranks. It goes up and down easy. It just when you put it up, the back part of the window is down about an inch while the front part of the window is in it's normal place. Any suggestions
Old Aug 11, 2012 | 08:07 PM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
Re: Passenger side window won't go up even. Ends up with window partly open?
Yup, take the door skin off and learn how to adjust it. There's tech articles and stuff.
Old Aug 14, 2012 | 01:27 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
You could also have a broken roller- check that your rollers on the window mechanism(there should be a total of three- the sizzor arms that lift the window have 4 ends total- one end has the gear on it in the crank mechanism, two ends go in the window track, the 4th end rides in a short length of track rear of center of the door). There is also a 4th roller attached to a stud in the window that rides in the vertical track just to the rear of the armrest area. That one is the usual mystery rattle that is the last one you seem to find when sorting out all the bangs and rattles in the door...
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
