Time For Another 4th Gen Seat Question
Old Feb 8, 2001 | 06:03 PM
Frank 84 Bird's Avatar
Car: 87 Trans Am
Transmission: TKO 600
I'm gonna be installing 94 Firebird seats tomorrow. I would'nt ask the question but my cars over an hour away in storage.
Do I have to take apart the seatbelt to fit it through the guide on the side of the seat? What's the best way to do it?
I just wanna make sure I bring the right tools with me.
Frank
[This message has been edited by Frank 84 Bird (edited February 08, 2001).]
Old Feb 8, 2001 | 08:45 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
The guide should just unbolt from the side of the seat and you shouldn't have to take apart the seat belts. Just take some torques cause that what is on the rear bench seat holding on the guide. I think the front is a screw driver.
Old Feb 8, 2001 | 08:59 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
Oh my bad I think that you mean using the new guides from the 94 seats. Now I'm not sure on that one. I just reused the guides on my old seats when I did the swap. I once took a seat belt from a car and it looked impossiable to take apart. You should try to use your old belts over or get new ones to match if thats the problem. I m not saying that it can't be done but it looks like a pain. I hope that this helps in anyway.
Old Feb 8, 2001 | 09:16 PM
Car: 87 Trans Am
Thanks for the info. Since the guides off the old seats will bolt up I'll use those.
Frank
Old Feb 9, 2001 | 12:19 AM
Drew's Avatar
Something you might run into, thirdgen seatbelt guides on 4th gen seats tend to raise the level of the belt. If you're short like me it'll go right across your neck and is a major pita during the summer.
Drew
The lone Thirdgenner of the Apocalypse
predatorman@hotmail.com
My Website
87 Iroc
91 Formula 14.3@98mph
91 RS Convertible
91 Firebird V6FOR SALE!
92 S10FOR SALE!
98 Grand Am GT
Old Feb 9, 2001 | 01:51 PM
ERIC'86IROC's Avatar
Drew you might get decapitated in a collision! I am installing 4th gen seats soon also. They gave me the seat belts also. Will the 4th gen belts bolt right up as well? I assume the rear will not since they are shoulder belts and my car only has lap belts in the rear.
350 Vortec, forged flat-tops, CompCams XE268, Edlebrock RPM, Holley 3310, TH350 w/Holeshot 2400, 3.23 posi, Heddman shorties, HEI
Old Feb 9, 2001 | 06:29 PM
Car: 87 Trans Am
I installed the seats this afternoon. I decided to use the seatbelt guides that came with the new seats. All I did was cut the guide near the mounting screws and slide the belt through the cut. The seats look awsome.
Later
Frank
Old Feb 10, 2001 | 12:10 AM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
I just put a set in my IROC 2 weeks ago, and I like them a lot better than the old leather seats I had. Did you have power seats in your car?
And where are you in CT? You should check out the CTFBA, check my sig for the website.
Member ofThe Connecticut F Body Association
Proud owner of the slowest L98 in the North East
1987 IROC 5.7 - 16.43 @ 82 the project
1986 S10 4x4 w/93 Vortec 4.3 - the nitemare
1988 Formula WS6 - the Cow
Old Feb 10, 2001 | 10:26 AM
Car: 87 Trans Am
My car did'nt have power seats in it. The new seats are'nt power either. So the install was real easy.
I live in Southington. That's cool that there's an F-Body club in CT. I'm gonna have to join.
Frank
Old Feb 10, 2001 | 04:22 PM
MikeDwhoROCZImports's Avatar
F-body club in CT? Sweet.
Old Feb 10, 2001 | 07:59 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
My car originally had power seats, but the new ones were manual. The tracks bolt right up though so I was able to use keep the power option. Only problem was the trim panel that holds the switch isn't the same so I need to make a custom one.. but that's no big deal.
As for CTFBA, I just joined up a few weeks ago. It seems like a cool bunch of people and there are some events already planned for the spring/summer. When I joined, 4th gens had the majority, but it's about even now with thirdgens.
You should both check it out for sure. I can't wait to hit some local events.
Member of The Connecticut F Body Association
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
