91 RS Hatch Latch Unit Inoperable, Not Getting Power, Suggestions?
Old Aug 19, 2012 | 09:12 PM
RS3's Avatar
RS3
Car: 1991 Camaro RS
Engine: 305 TBI
My 91 RS hatch doesnt shut all the way. It latches and opens with the key but I can lift it up a little and it wont shut all the way. I took off the interior panel and it looks like there is a pull down motor cause I see plastic tracks and a slider on the bottom of the latch mechanism. I tried testing it with a voltmeter, black probe to frame and red to all of the wires feeding into a black relay and all of the wiring harness connector ports. Couple wires got me 0.20V, the rest were cold. Read on some other forum posts that this could be fixed in a number of ways. How did you guys fix yours?
Old Aug 26, 2012 | 10:31 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: 91 RS Hatch Latch Unit Inoperable, Not Getting Power, Suggestions?
Read the Tech Atricle I wrote. It will help you doagnose and repair your hatch pull-down unit.
https://www.thirdgen.org/tech/hatchpulldown.pdf
Good Luck, Lon
Old Aug 26, 2012 | 10:37 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Is the frame of the assembly bolted to the body plastic, or metal ?
Old Aug 26, 2012 | 10:54 PM
lonsal's Avatar
Thanks for asking the question. We'll need to know if the frame is tan colored plastic or metal. THe instructions I sent are for the metal version.
Lon
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
Randomtask2
Aug 13, 2015 01:57 AM
z28addict8490
Aug 7, 2015 08:48 PM
