A/C vents
Old Feb 13, 2001 | 08:51 PM
TMoNeE's Avatar
Car: 87 Z28
A/C vents
All of my A/C vents inside my car are like loose.. like if you tilt it up it just falls down.. is there a way to fix this?
89 RS 305 TBI
Edelbrock 14x3 OE intake, Hypertech Chip, Street & Strip shift kit, flowmaster exhaust w/ high flow catco cat.
AIM:TiMoThY9801
Stereo:
JVC Detachable face cd player w/ 2 Pioneer 12" subs in custom box, powered by Lanzar 600 watt amp.
Old Feb 13, 2001 | 10:29 PM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
How I fixed a couple of mine was to take out the vent and put a piece of double sided tape onto it and then put it back in The only draw back is that you can't adjust the vent up or down, although you can still adjust the "slats"
"5 out of 4 people have a problem with fractions"
My Camaro: http://home.earthlink.net/~singleton052095
Old Feb 14, 2001 | 12:16 AM
gwman's Avatar
Get some gasket material and cut out a circle about the size of a dime. Then punch a small hole in the center for the stud on the vent to go through. put the material on the stud and snap the vent back into place. Works like a champ!
Old Feb 14, 2001 | 03:28 AM
Jza's Avatar
Jza
I used a small strip of adhesive foam rubber, but left the paper backing on the other side. The pressure is enough to hold it in place, but the paper backing lets it slip enough that you can still adjust it.
Jza's Avatar
Jza
[double post]
[This message has been edited by Jza (edited February 14, 2001).]
Old Feb 14, 2001 | 05:56 AM
TMoNeE's Avatar
Car: 87 Z28
Also, is there an easy way to take em out.. Ive never tried so this may be a stupid post... but when I do I dont want to break em
Old Feb 14, 2001 | 04:43 PM
Tonyrodz's Avatar
Transmission: auto
How about some felt? I think that's what they originally had in it. I took mine out by sticking a very thin flat screw driver in there and pushing it to the side--should pop right out. Be careful tho you don't want to break it.
Old Feb 15, 2001 | 02:35 AM
Jza's Avatar
Jza
Here's a less risky way to take them out:
Push on the outside frame of the vent piece (push on the louvers and you'll break those out) near the center post until it goes into the vent. Then pull the opposite side out and slide the whole thing out at an angle.
This is because the pegs are sort of "spring-loaded" and rounded. Pushing them in recesses the peg enough to pull the vent out.
Getting them back in is a little bit trickier, but by then you'll see what I mean and can figure it out.
[This message has been edited by Jza (edited February 15, 2001).]
Old Feb 15, 2001 | 04:49 PM
MikeS's Avatar
and once you get them out, i like the gasket material or rubber washer idea. i just put a metal washer on one of the pegs on mine and it works fine. would have gone with something smaller, softer, and blacker if i had it around at the time though.
Old Feb 15, 2001 | 11:47 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
I just did the ones on my pick up.
I used small O-rings on each end.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
Fanatic1074
Oct 2, 2015 03:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
