What is this part called?
Old Aug 21, 2012 | 10:19 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
It connects the key lock to the actual locking mechanism inside the door. Mine is broken and i need To replace it but can't find anything on it.
Anybody have any idea on what it's called or where I can find one?
Thank you
My phone won't let me attach a pic. It's a small round piece of steel about 5 inches long with plastic connectors on it to connect to the lock and to the locking mechanism.
Old Aug 21, 2012 | 10:33 PM
86F.BiRD's Avatar
Car: 1986 Pontiac Firebird Base
Engine: SBC 350
Transmission: Borg Warner T-5 World Class
Axle/Gears: 4th Gen Rear with 3.73s
Re: What is this part called?
Try these...
1. Hawksthirdgenparts.com
2. Thirdgenranch.com
3. ClassicIndustries.com
4. EcklersCamaro.com
Old Aug 21, 2012 | 11:14 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Is it the metal rod or the plastic connectors. They used to be on classic Industries website, now they are gone.. I would recommend a GM dealship parts department if you can't find...
Old Aug 22, 2012 | 06:18 AM
LHernandezJr's Avatar
For that type of part, a salvage yard/pick-and-pull may be a good place to check.
Old Aug 22, 2012 | 08:50 AM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
It's the plastic connector. I Will call a dealer and see if they have them. Thanks
Old Aug 23, 2012 | 07:07 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
You need to post a pic................
My guess is a lock pawl.
Old Aug 23, 2012 | 07:14 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
You can get those plasctic connectors at a body shop supply store.
Old Aug 23, 2012 | 10:43 AM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Finally got to upload one. My door is missing the pawl (thanks for that part name) and the plastic connector is broken.
ive called a few local body shops and none carry the pawls or the plastic connectors.
Any idea on a online site that i can order these from?
Id rather not go to a junkyard and have to rip a door apart just to pull a rusted, semi broken part out and deal with this again in the future.
thanks
Old Aug 23, 2012 | 08:02 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Several online camaro parts places have the pawl and lock rod "clips".
Usually listed under the lock section in their catalogues.
Old Aug 23, 2012 | 08:09 PM
39lasalle's Avatar
Door lock rod clips, NAPA Auto should have them them in stock
39
Old Aug 27, 2012 | 12:41 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
thanks everyone for the help! a TGO member is sending me a pair.
Old Aug 27, 2012 | 07:13 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
You can go to every autoparts store in the nation and pick those plastic connectors up. The rod should be reusable.
Old Aug 28, 2012 | 06:49 AM
ibmtech's Avatar
Car: 1987 IROC-Z
I have seen them at Autozone / Advance Auto / Napa before. . They are usually located in the self help section and very cheap
Old Aug 29, 2012 | 04:25 AM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
yep, almost all local parts stores have them in the help section for a few bucks.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
86White_T/A305
Aug 17, 2015 12:16 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
