tail light swap
Old Aug 25, 2012 | 12:58 PM
raith's Avatar
Car: 92 Camaro RS, 84 Recaro T/A
Engine: LS2, none in the TA at the moment
Transmission: T56, 700r4
Axle/Gears: 3.23 posi, G80 LSD
tail light swap
does anyone know if the 2 piece tail light assembly from the 91-92 birds can be swapped out for an older 3 piece setup?
Old Aug 25, 2012 | 01:13 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: tail light swap
Physically yes, but the bulb arrangement is different & will require some rewiring.
Old Aug 25, 2012 | 11:43 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: tail light swap
you can get the harness from the car they came from or another car that had these style lights and pull your harness as it connects behind the dr side panel below the speaker. if its anything like when i did my
formula to 85-90 TA tail light swap it should be a plug and play deal.
Frozer!!!
Jan 19, 2024 04:55 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Omega
Aug 10, 2015 12:46 PM
