Fuel Pressure Gauge Pod...HELP!
Old Feb 20, 2001 | 04:42 AM
CarNDrvr's Avatar
Has anyone used a mechanical fuel pressure gauge in a pilar pod? I know that it has the isolator, but what kind of line comes off of the gauge itself and runs to the isolator? Is there enough room under the pilar to run this line?
1991 Camaro RS, approximately 500hp 355, 11:1 compression, Eagle h-beam rods, forged steel crank, TRW lightweight 2 valve relief pistons, comp cams hydraulic roller, fully ported Dart Iron Eagle heads, Victor Jr., Holley 750, Hooker shorty headers w/3" collector, true dual 3" exhaust, Moroso spiral mufflers, T56 6-speed, Boyd Coddington 17x9, 17x11 wheels, 275/40zr17 fronts, 315/35zr17 rears, Cerillo racing seats w/ harnesses, Harwood cowl hood, 4:10 posi, Global West adjustable rear suspension and panhard bar, Hotchkis front and rear springs, 1LE sway bars, Koni shocks.
Old Feb 20, 2001 | 10:31 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I am told it can be done with an isolator as you describe. But an electric fuel pressure gauge is a lot easier to install and just as accurate.
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
Kaweh
Aug 9, 2015 02:54 PM
