that light in the cargo area?
Old Feb 20, 2001 | 09:13 AM
zee28's Avatar
Car: 86 iroc
my 86 has a light and a switch beside it.the 92 rs im using for interior parts only has a light,no switch.Do i need the switch when I put the 92 plastic in?I dont even know what the switch is for.its a 3 position switch but only works if I turn it on ,not when the hatch or doors are open.is it broke anyway?thanks
~mike~86 IROC-Z
Old Feb 20, 2001 | 09:42 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
I think where the difference lies is in the '86 not having a power pull-down hatch. I believe they came to be in '87. I have a '91, and the light is activated by the power hatch release switch. I don't know how easy it would be, but you may be able to convert yours over to use the power pull-down, I dunno...
KAM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
From 90-92 the hatch light came on automatically. There must be a mercury switch of some type, but I haven't found it yet. Your 86 hatch light only comes on when you turn on that switch you are asking about. You have two choices: If you can trace back the wiring for the hatch light in the 92 and find the switch that turns it on automatically, then you can add it to your 86. Otherwise you will need to cut a hole in the 92 plastic and install the manual switch. I added the manual switch to my 90 just so I have the option of opening my trunk (convertible) and leaving the light turned off. Good luck, Lon.
Old Feb 20, 2001 | 11:25 AM
HighHorseZ's Avatar
<font face="Verdana, Arial" size="2">Originally posted by thunderstick:
KAM
</font>
The 86's came with the power pull down hatch. Well, mine did anyway.
Old Feb 20, 2001 | 11:38 AM
zee28's Avatar
Car: 86 iroc
yeh, 86 had power hatches.I guess I will just cut the hole.thanks.I also noticed that the 92 has bigger/wider holes for the t-top bag straps,wonder why?
~mike~86 IROC-Z
Old Feb 20, 2001 | 06:48 PM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
my 86 had the power pull down. that switches function is to simply tell the light if it comes on automaticly with the hatch up or not. thats it
I have experience...unfortunatly,its a result of bad judgement.
click below to check out MY FORMULA PAGE!
http://www.formula350.com
or click below to email me
astralbaby11@hotmail.com
Old Feb 20, 2001 | 10:42 PM
lonsal's Avatar
Thunderstick: I found the "mystery" switch. It is the same switch that causes the pull down to activate. Mystery solved, thanks.
I'llrocya
Feb 2, 2016 11:43 PM
tcarlos13
Interior Parts Wanted
Sep 2, 2015 07:29 PM
Fronzizzle
Aug 19, 2015 01:36 PM
fonzie85
Aug 13, 2015 11:50 AM
Omega
Aug 10, 2015 12:46 PM
