ground efx goin bye bye...
Old Aug 26, 2012 | 11:23 AM
Jason C. Laney's Avatar
Car: '90 rs
Engine: 305 tbi for now
Axle/Gears: stock rear for now
been searchin quite a bit here, can't come up with a definate answer. got a 90 RS with all the ground efx. i'm wanting to remove all of them thus making a basic coupe body, like the berlinetta's. a 3rd gen boneyard close to me says it can't be done. says the front and rear bumper/nose covers wont fit or line up. is he right? seems to me it should as the efx merely bolt on to the body. yes, i will have holes to fill, along with other unrelated body work to do, no problemo. simply want to know if i can take the front nose and rear cover off a coupe and bolt them onto my car without issue
Old Aug 26, 2012 | 11:44 AM
87cam305's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 305 (LG4)
Re: ground efx goin bye bye...
yes.
Old Aug 26, 2012 | 11:45 AM
Car: '90 rs
i thought so. thank you.
Old Aug 26, 2012 | 03:26 PM
87cam305's Avatar
Engine: 305 (LG4)
No problem. the only problem I can see you might have in removing the Gfx is the rocker pieces are screwed to a metal bracket that is spot welded to the rocker panel. but with a good spot weld cutter it should go smoothly.
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
Thaney9
Oct 15, 2015 06:37 AM
lewandom
Oct 1, 2015 08:15 AM
