Power seats?
Old Feb 20, 2001 | 06:44 AM
custman87T/A's Avatar
Power seats?
I am finally getting around to putting in the RECARO seats I had redone. My question is for the power seat there are 2 wires comming off the harness 1 orange and 1 black, I assume the black is ground and the orange is a switched lead, am I correct on this? and should I run a fuse on the line if so what amperage??? thanks
Old Feb 20, 2001 | 02:29 PM
David Petersen's Avatar
I just removed my entire wiring harness and yes the black is ground and is grouned to the elevated bar in the floor where the seat bolts are just to the left of the seat. The orange wire runs to a black power box you should just be able to add plug into that is located on the drivers side mounted to the side of the car just above the hood realease with a bunch of orange wires going to it.
Old Feb 21, 2001 | 12:13 AM
Tad's Avatar
Tad
The box he is talking about is an accessories power supply. It has two sides One is switch and the other is hot al the time. the orange wire suold go to the hot side.
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
