Headlights
Car: 1991 Pontiac Firebird Formula
Engine: V-8 305
Transmission: Unknown
Axle/Gears: Unknown
Headlights
I have a 1991 Firebird and i know the Driver side headlight motor is out, its got no power. The passenger side is still good,it used to come up with no problem and stay up,Now the light doesn't come up at all i have to manually lift it and does not stay up. I know the motor is still good cause i can hear it running. What do u think the problem may be ? Is their anyway i can just put up the lights without the motors and keep them up ? Also the trunk pull down motor works too as i can hear it trying to latch but just can't,therefore the trunk don't close all the way. Any fix to these issues ?
Car: 1986 camaro
Transmission: 5 speed manual t5
Re: Headlights
I know when my wipers on my old car i would turn them on and hear the motor running but no movement there was a nut that was tightend down so it might just be that somethings loose check everything and make sure its snug
Car: 1984 Trans am
Engine: 305 H.O.
Re: Headlights
I'd just change the motors. I just did this on my t/a, not hard. Passenger side motor was slow, sometimes would stick up or down so i changed it and then realized the drivers side was slow, so i changed it too. 3 Bolts, a nut and the plug, that's all
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: Headlights
The passenger side may just need a bushing kit available at Top Down Solutions. The driver side needs to be determined if it is getting power or not. If no power you will need to check back further. It may be the relay. If it is getting power but the motor is not turning then probably need to replace the motor with another later style two wire motor.
Sorry I do not know much about the powered hatch motors even though I have it on my Bird.
Axle/Gears: 3.45, 3.27, 3.27
Re: Headlights
Yes I have repair kits for both the your headlights (TDS 207280 or TDS 209280) and the rear hatch pull-down notor. (TDS 204040 or TDS 300310).
Lon
Lon
Engine: V-8 305
Axle/Gears: Unknown
Re: Headlights
I have a replacement bracket and motor for the hatch already.Just thought id try to fix the one i have installed. The Headlights i was wondering if i can just keep them up without the motor. I was told with the older cars with the flip lights there was a switch or something to keep em up !
Re: Headlights
http://www.top-downsolutions.com/Bod...ight-motor-kit
TDS 209280 deluxe headlight repair kit is $20.25 contains enough to repair a pair of headlights. It contains 6 Delrin bushings, two side cover gaskets, one motor gasket, two screws & nuts (in case you snap off some during the repair) and a packet of synthetic grease. Both kits include a detailed multi-page instruction sheet.
http://www.top-downsolutions.com/Bod...ght-repair-kit
Lon
Engine: V-8 305
Axle/Gears: Unknown
Re: Headlights
thanks but i Just got them to stay up and unplugged the motors. I have a new problem though,my hood isn't closing !
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Headlights
Don't be THAT guy, driving around with your headlights stuck up. Fix it right. Please.
Re: Headlights
It will balance out OK. The reduced mpg he is getting from having the headlights up day and night will be offset by the increase in mpg he gets from the weight reduction of driving without a hood.
Lon
Lon
Car: 89 Formula
Engine: 383 SBC/HSR
Engine: V-8 305
Axle/Gears: Unknown
Re: Headlights
I will get the lights repaired when i can afford it.The hood latch needs replaced too. I just can't Afford everything right now.
Car: 89 Formula
Engine: 383 SBC/HSR
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Re: Headlights
If you install the complete new motors do you have the remove the headlight assy's fromt the car like you do if you do the rebuild kit. I have the TDS rebuild kit, but thinking about just getting the new motors as Summit Racing has then kinda cheap and don't feel like taking the headlights out.
