Power Door Locks
Old Aug 27, 2012 | 09:10 PM
N_da_Mood's Avatar
Car: 1992 Z28 Heritage Edition
Power Door Locks
I have searched around but I have not found a sure fire way to "renew" the power door locks, I usually have to hit the unlock or lock buttons 4-5 times before it goes the whole way, does anyone know how to renew the actuators or anything?
Old Aug 27, 2012 | 11:01 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Power Door Locks
Many people have written about taking off the door inner panel and cleaning and lubricating the shafts and actuators, etc. Here's on thread about it. Searching should turn up more.
https://www.thirdgen.org/forums/inte...ock-issue.html
Old Aug 27, 2012 | 11:32 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Often the problem is slop that developes in the connecting joints. You can invest in the new plastic joints or wrap them with a zip-tie to take up the slop.
Lon
Old Aug 28, 2012 | 08:07 PM
N_da_Mood's Avatar
Henry: I tried to search but I couldnt find the one you sent me and that sounds perfect. Thanks alot!
Lon: That is a great idea because that is what it looks like that it just has alot of slop I will give it a try on friday and give you guys the update!
Thanks!!
Old Sep 4, 2012 | 02:36 PM
N_da_Mood's Avatar
Well I have finished renewing my door locks and found that all of the plastic clips were new from the previous owner, but the mechanism just needed a good oiling and a rod was bent in one of the doors which was jamming it up, thanks for all your help!
Old Sep 4, 2012 | 03:22 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Cool, now I need to get around to doing this...
Old Sep 4, 2012 | 03:27 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
On the little pivots that the lock actuator pushrods connect to there are springs that center them up, if you remove them it improves the movement of the locks quite a bit, and I never found any adverse effects.
Old Sep 4, 2012 | 04:05 PM
82tarecaro's Avatar
I put new motors, and cleaned and lubricated the lock mechanism. I took the whole mechanism out and soaked it in degreaser and then lubed the mechanism with white lithium grease. I probably didn't need new motors but I figured it was all apart and the motors aren't big money. Anyway - the locks work like new now. I think all the old crud has to be cleaned out for the locks to work properly.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
